Datasheet Texas Instruments LM3S9D96-IBZ80-A2 — Даташит
СерияLM3S9D96
МодельLM3S9D96-IBZ80-A2
Микроконтроллер Stellaris LM3S 108-NFBGA от -40 до 85
Stellaris LM3S9D96 Microcontroller Data Sheet datasheet
PDF, 7.8 Мб, Версия: C, Файл опубликован: 3 июл 2014
Pin108108
Package TypeZCRZCR
Industry STD TermNFBGANFBGA
JEDEC CodeS-PBGA-NS-PBGA-N
CarrierJEDEC TRAY (5+1)JEDEC TRAY (5+1)
МаркировкаLM3S9D96IBZ80
Width (мм)1010
Length (мм)1010
Thickness (мм).95.95
Pitch (мм).8.8
Max Height (мм)1.51.5
RoHSНе совместим
  • Serial-to-Ethernet Converter for Stellaris Microcontrollers (AN01266)
    PDF, 89 Кб, Файл опубликован: 7 июл 2009
    The software described in this application note allows an Ethernet-enabled Stellaris microcontroller to be used as a serial-to-Ethernet converter.
  • Using the Stellaris Ethernet Controller with Lightweight IP (lwIP) (AN01261) (Rev. C)
    PDF, 70 Кб, Версия: C, Файл опубликован: 8 сен 2012
  • Configuring StellarisВ® Tempest- and Firestorm-Class and MCUs W/ Pin Multiplexing (Rev. C)
    PDF, 172 Кб, Версия: C, Файл опубликован: 6 ноя 2013
    Many members of the StellarisВ® family of microcontrollers provide system designers with a great deal of control over the placement and selection of peripheral module signals that are alternate functions for GPIO signals. This application note provides an overview of the pin muxing implementation, an explanation of how a system designer defines a pin configuration, and examples of the pin confi
  • USB Certification for Stellaris-Based USB Peripherals and Embedded Host Systems
    PDF, 3.9 Мб, Файл опубликован: 7 июл 2009
    This application note describes the USB-IF certification process for a USB full-speed device and a USB full-speed embedded host system using the a Stellaris LM3S5732 microcontroller as the example.
  • Using the Stellaris Ethernet Controller with Micro IP (uIP) (AN01260) (Rev. B)
    PDF, 128 Кб, Версия: B, Файл опубликован: 11 янв 2010
    This application note gives an overview of the uIP TCP/IP stack followed by a discussion of uIP application examples provided for Stellaris evaluation boards with Ethernet controllers.
LM3S9D96IBZ80A2, LM3S9D96 IBZ80 A2
На английском языке: Datasheet Texas Instruments LM3S9D96-IBZ80-A2
