Datasheet Texas Instruments MSP430AFE232IPW — Даташит
СерияMSP430AFE232
МодельMSP430AFE232IPW
16-битный микроконтроллер со сверхнизким энергопотреблением, флэш-память 8 КБ, ОЗУ 512 Б, 2x SD24 24-TSSOP от -40 до 85
MSP430AFE2x3, MSP430AFE2x2, MSP430AFE2x1 Mixed Signal Microcontroller datasheet
PDF, 1.4 Мб, Версия: A, Файл опубликован: 21 мар 2011
Pin24
Package TypePW
Industry STD TermTSSOP
Package QTY60
Маркировка430AFE232
Width (мм)4.4
Length (мм)7.8
Thickness (мм)1
Max Height (мм)1.2
ADCSigmaDelta24 - 2ch
AESN/A
Active Power220 uA/MHz
Additional FeaturesWatchdog,Temp Sensor,Brown Out Reset
BSLUART
CPUMSP430
Тактовая частота12 МГц
GPIO Pins11
Max VCC3.6
Min VCC1.8
Multiplier16x16
Non-volatile Memory8 KB
Package GroupTSSOP
Package Size: mm2:W x L24TSSOP: 50 mm2: 6.4 x 7.8(TSSOP) PKG
RAM0.5 KB
SPI1
Special I/ON/A
Standby Power0.5 LPM3-uA
Timers - 16-bit1
UART1
Wakeup Time1 us
  • Evaluation Modules & Boards: MSP-TS430PW24
    MSP-TS430PW24 - 24-pin Target Development Board for MSP430AFEx MCUs
  • Evaluation Modules & Boards: MSP-NRGWTCHDG
    MSP430 Energy Watchdog Tool
    MSP EnergyTrace Technology
  • Implementation of a Single-Phase Electronic Watt-Hour Meter Using MSP430AFE2xx (Rev. A)
    PDF, 2.0 Мб, Версия: A, Файл опубликован: 10 май 2013
    This application report describes the implementation of a single-phase electronic electricity meter using the Texas Instruments MSP430AFE2xx metering processors. It includes the necessary information with regard to metrology software and hardware procedures for this single chip implementation.
  • Interfacing the MSP430AFE2xx Based Single-Phase E-Meter with a Host Processor
    PDF, 1.2 Мб, Файл опубликован: 24 сен 2014
    This application report describes the implementation of a single-phase electronic electricity meter using the Texas Instruments MSP430AFE25x metrology family of processors in two-chip architecture. The metering processor (MSP430AFE25x) assumes the role of a slave controlled by a host microcontroller (MCU), the MSP430F663x.
  • Energy Measurement Results for TI Designed Meter Using MSP430AFE2xx Devices
    PDF, 763 Кб, Файл опубликован: 30 июл 2012
    This application report describes the results obtained on a single phase electronic electricity meter using the Texas Instruments MSP430AFE2xx metering processors. These tests are indicative of the performance of a meter designed by Texas Instruments and is subject to differ based on sensor selection, board layouts and other design considerations. The results include energy accuracies for active a
  • Programming With the MSP430AFE2xx Family and the MSP430i20xx Family
    PDF, 89 Кб, Файл опубликован: 10 авг 2014
    This application report enables the easy incorporation of the MSP430AFE2xx family of MCUs, featuring the SD24_A module, as well as the MSP430i20xx family of MCUs, which features the SD24 module, into new designs. It covers programming, system, and peripheral considerations when creating firmware. The intent is to highlight a few key differences between the two families and how to incorporate each
  • Migrating from the MSP430F2xx,G2xx Family to the MSP430FR58xx/FR59xx/68xx/69xx (Rev. E)
    PDF, 179 Кб, Версия: E, Файл опубликован: 3 ноя 2016
    This application report enables easy migration from MSP430F2xx flash-based MCUs to the MSP430FR58xx/FR59xx/68xx/69xx family of FRAM-based MCUs. For the migration guide to MSP430FR57xx, see Migrating From the MSP430F2xx Family to the MSP430FR57xx Family. It covers programming, system, and peripheral considerations when migrating firmware. The intent is to highlight key differences between the two f
  • MSP Code Protection Features
    PDF, 752 Кб, Файл опубликован: 7 дек 2015
    MSP microcontrollers (MCUs) offer a number of features to help control code accessibility in the device, to add different layers of code access management and protection strategies. These include features that can lock or password protect the JTAG/SBW access, IP Encapsulation (IPE) to isolate sensitive code with different permissions than the rest of the program, and bootloader (BSL) access featur
  • Design Considerations When Using the MSP430 Graphics Library
    PDF, 475 Кб, Файл опубликован: 5 окт 2012
    LCDs are a growing commodity in todays market with products as diverse as children's toys to medical devices. Modern LCDs, along with the graphics displayed on them, are growing in complexity. A graphics library can simplify and accelerate development while creating the desired user experience. TI provides the MSP430 Graphics Library for use in developing products with the MSP430в„ў MCU. This
  • ESD Diode Current Specification
    PDF, 520 Кб, Файл опубликован: 7 дек 2015
    This document explains the maximum ESD diode current specified for GPIO on MSP microcontrollers. Sometimes signals on specific pins exceed the supply of the MSP MCU. In such a case, the device can handle this overvoltage condition through the ESD diodes, but the ESD diode specification must be considered during application design. The items to be considered are described in this document.
Серия: MSP430AFE232 (2)
  • Semiconductors > Microcontrollers (MCU) > MSP430 ultra-low-power MCUs > MSP430F2x/4x
На английском языке: Datasheet Texas Instruments MSP430AFE232IPW
