Datasheet MAX3074EASA+ - Maxim Даташит ИС RS422/RS485 TXRX 250KBPS 3.63 В SOIC-8 — Даташит
Наименование модели: MAX3074EASA+
37 предложений от 21 поставщиков Интегральные микросхемы Интерфейс - Драйверы, Приемники, Трансиверы | |||
MAX3074EASA+T Maxim | 65 ₽ | ||
MAX3074EASA Maxim | от 305 ₽ | ||
MAX3074EASA+ Maxim | от 1 066 ₽ | ||
MAX3074EASA+T Analog Devices | по запросу |
Производитель: Maxim
Описание: ИС RS422/RS485 TXRX 250KBPS 3.63 В SOIC-8
19-2668; Rev 1; 1/03
+3.3V, ±15kV ESD-Protected, Fail-Safe, Hot-Swap, RS-485/RS-422 Transceivers
General Description
The MAX3070EMAX3079E 3.3V, ±15kV ESD-protected, RS-485/RS-422 transceivers feature one driver and one receiver.
These devices include fail-safe circuitry, guaranteeing a logic-high receiver output when receiver inputs are open or shorted. The receiver outputs a logic high if all transmitters on a terminated bus are disabled (high impedance). The MAX3070EMAX3079E include a hot-swap capability to eliminate false transitions on the bus during power-up or hot insertion. The MAX3070E/MAX3071E/MAX3072E feature reduced slew-rate drivers that minimize EMI and reduce reflections caused by improperly terminated cables, allowing error-free data transmission up to 250kbps. The MAX3073E/MAX3074E/MAX3075E also feature slewrate-limited drivers but allow transmit speeds up to 500kbps. The MAX3076E/MAX3077E/MAX3078E driver slew rates are not limited, making transmit speeds up to 16Mbp
- Device Type: Transceiver
- IC Interface Type: RS422, RS485
- Количество драйверов: 1
- Диапазон напряжения питания: 2.97 В ... 3.63 В
- Тип корпуса: SOIC
- Количество выводов: 8
