Datasheet LMH6521SQE - National Semiconductor Даташит Усилитель, DVGA, 200 МГц, сдвоенный, 32LLP — Даташит
National Semiconductor LMH6521SQE
Наименование модели: LMH6521SQE
21 предложений от 13 поставщиков
Микросхема Операционный усилитель, TEXAS INSTRUMENTS LMH6521SQE Programmable/Variable Amplifier, 2Channels, 1 Amplifier, 1.2GHz, -40℃, 85℃, 4.75V to 5.25V
727GS
LMH6521SQE/NOPB
от 47 ₽
LMH6521SQE
306 ₽
LMH6521SQE/NOPB
от 1 258 ₽
Элитан
LMH6521SQE
1 519 ₽
Описание: Усилитель, DVGA, 200 МГц, сдвоенный, 32LLP
data sheetСкачать Data Sheet
LMH6521 High Performance Dual DVGA
September 14, 2011
General Description
The LMH6521 contains two high performance, digitally controlled variable gain amplifiers (DVGA).
Both channels of the LMH6521 have an independent, digitally controlled attenuator followed by a high linearity, differential output amplifier. Each block has been optimized for low distortion and maximum system design flexibility. Each channel has a high speed power down mode. The internal digitally controlled attenuator provides precise 0.5dB gain steps over a 31.5dB range. Serial and parallel programming options are provided. Serial mode programming utilizes the SPITM interface. A Pulse mode is also offered where simple up or down commands can change the gain one step at a time. The output amplifier has a differential output allowing 10VPPD signal swings on a single 5V supply. The low impedance output provides maximum flexibility when driving filters or analog to digital converte
  • Диапазон напряжения питания: 4.75 В ... 5.25 В
  • Количество выводов: 32
  • Количество каналов: 2
  • Количество усилителей: 1
  • Полоса частот: 1.2 ГГц
  • Рабочий диапазон температрур: -40°C ... +85°C
  • Тип корпуса: LLP
  • Точность коэффициента усиления: 1%
  • RoHS: да
  • SVHC: No SVHC (19-Dec-2011)
На английском языке: Datasheet LMH6521SQE - National Semiconductor AMP, DVGA, 200 MHz, DUAL, 32LLP
