Datasheet AT91SAM9G15-CU - Atmel Даташит Микроконтроллеры (MCU) BGA GRN IND TMP MRLA — Даташит
Наименование модели: AT91SAM9G15-CU
![]() 25 предложений от 17 поставщиков Микросхема Микроконтроллер, ATMEL AT91SAM9G15-CU 32Bit Microcontroller, ARM9, 400MHz, 32KB, 32KB, 217Pins, BGA | |||
AT91SAM9G15-CU Atmel | 373 ₽ | ||
AT91SAM9G15-CU Microchip | от 1 487 ₽ | ||
AT91SAM9G15-CU Microchip | по запросу | ||
AT91SAM9G15-CU-999 Atmel | по запросу |
Производитель: Atmel
Описание: Микроконтроллеры (MCU) BGA GRN IND TMP MRLA
Features
· Core
ARM926EJ-STM ARM® Thumb® Processor running at up to 400 MHz @ 1.0V +/- 10% 16 Kbytes Data Cache, 16 Kbytes Instruction Cache, Memory Management Unit Memories One 64-Kbyte internal ROM embedding bootstrap routine: Boot on NAND Flash, SDCard, DataFlash® or serial DataFlash.
Programmable order. One 32-Kbyte internal SRAM, single-cycle access at system speed High Bandwidth Multi-port DDR2 Controller 32-bit External Bus Interface supporting 8-bank DDR2/LPDDR, SDR/LPSDR, Static Memories MLC/SLC NAND Controller, with up to 24-bit Programmable Multi-bit Error Correcting Code (PMECC) System running at up to 133 MHz Power-on Reset Cells, Reset Controller, Shut Down Controller, Periodic Interval Timer, Watchdog Timer and Real Time Clock Boot Mode Select Option, Remap Command Internal Low Power 32 kHz RC and Fast 12 MHz RC Oscillators Selectable 32768 Hz Low-power Oscillator and 12 MHz Oscillator One PLL for the system and one PLL at 480 MHz optimized for US
- Шина данных: 32 бит
- RoHS: да
AT91SAM9G15CU, AT91SAM9G15 CU
