Компактное аудиорешение Nuvoton NSP2340BA24E
Datasheet AT91SAM9G46-CU - Atmel Даташит Микроконтроллеры (MCU) IND TEMP CRYPTO, MRLA — Даташит
Atmel AT91SAM9G46-CU
Наименование модели: AT91SAM9G46-CU
Производитель: Atmel
Описание: Микроконтроллеры (MCU) IND TEMP CRYPTO, MRLA
data sheetСкачать Data Sheet
Features
· 400 MHz ARM926EJ-STM ARM® Thumb® Processor
­ 32 KBytes Data Cache, 32 KBytes Instruction Cache, MMU
· Memories
­ 4-port, 4-bank DDR2/LPDDR Controller ­ External Bus Interface supporting 4-bank DDR2/LPDDR, SDR/LPSDR, Static Memories, CompactFlash, SLC NAND Flash with ECC ­ One 64-KByte internal SRAM, single-cycle access at system speed or processor speed through TCM interface ­ One 64-KByte internal ROM, embedding bootstrap routine Peripherals ­ LCD Controller supporting STN and TFT displays up to 1280*860 ­ ITU-R BT.
601/656 Image Sensor Interface ­ Dual High Speed USB Host and a High Speed USB Device with On-Chip Transceivers ­ 10/100 Mbps Ethernet MAC Controller ­ Two High Speed Memory Card Hosts (SDIO, SDCard, e.MMC and CE ATA) ­ AC'97 controller ­ Two Master/Slave Serial Peripheral Interfaces ­ Two Three-channel 16-bit Timer/Counters ­ Two Synchronous Serial Controllers (I2S mode) ­ Four-channel 16-bit PWM Controller ­ Two Two-wire Interfaces ­ Four USARTs with ISO7816,
  • RoHS: да
AT91SAM9G46CU, AT91SAM9G46 CU
На английском языке: Datasheet AT91SAM9G46-CU - Atmel Microcontrollers (MCU) IND TEMP CRYPTO, MRLA
Политика конфиденциальности
