Datasheet AT91SAM9M11-CU - Atmel Даташит Микроконтроллеры (MCU) IND TEMP MRL А — Даташит
Наименование модели: AT91SAM9M11-CU
Производитель: Atmel
Описание: Микроконтроллеры (MCU) IND TEMP MRL А
Features
· 400 MHz ARM926EJ-STM ARM® Thumb® Processor
32 KBytes Data Cache, 32 KBytes Instruction Cache, MMU
· Memories
4-port, 4-bank DDR2/LPDDR Controller External Bus Interface supporting 4-bank DDR2/LPDDR, SDR/LPSDR, Static Memories, CompactFlash®, SLC NAND Flash with ECC One 64-KByte internal SRAM, single-cycle access at system speed or processor speed through TCM interface One 64-KByte internal ROM, embedding bootstrap routine Peripherals Universal Video Decoder provides decoding at up to 30 fps at D1 (720 x 576 pixels) or WVGA (800 x 480) resolution LCD Controller supporting STN and TFT displays up to 1280*860 ITU-R BT.
601/656 Image Sensor Interface Dual High Speed USB Host and a High Speed USB Device with On-Chip Transceivers 10/100 Mbps Ethernet MAC Controller Two High Speed Memory Card Hosts (SDIO, SDCard, e.MMC and CE ATA) AC'97 controller Two Master/Slave Serial Peripheral Interfaces Two Three-channel 16-bit Timer/Counters Two Synchronous Ser
- Шина данных: 32 бит
- RoHS: да
AT91SAM9M11CU, AT91SAM9M11 CU
