Datasheet MAX912CSE+ - Maxim Даташит ИС, прецизионный COMP, сдвоенный, 10 нс, SOIC-16 — Даташит
Наименование модели: MAX912CSE+
![]() 38 предложений от 24 поставщиков Аналоговый компаратор, низкой мощности, Точность, 2 Компаратора, 10 нс, 4.5В до 5.5В, -2В до -7В | |||
MAX912CSE-T Maxim | 65 ₽ | ||
MAX912CSE-T Maxim | 387 ₽ | ||
MAX912CSE-T Maxim | по запросу | ||
MAX912CSE Maxim | по запросу |
Производитель: Maxim
Описание: ИС, прецизионный COMP, сдвоенный, 10 нс, SOIC-16
19-0157; Rev 2; 8/03
Single/Dual, Ultra-Fast, Low-Power Precision TTL Comparators
General Description
The MAX913 single and MAX912 dual, high-speed, low-power comparators have differential inputs and complementary TTL outputs.
Fast propagation delay (10ns, typ), extremely low supply current, and a wide common-mode input range that includes the negative rail make the MAX912/MAX913 ideal for low-power, high-speed, single +5V (or ±5V) applications such as V/F converters or switching regulators. The MAX912/MAX913 outputs remain stable through the linear region. This feature eliminates output instability common to high-speed comparators when driven with a slow-moving input signal. The MAX912/MAX913 can be powered from a single +5V supply or a ±5V split supply. The MAX913 is an improved plug-in replacement for the LT1016. It provides significantly wider input voltage range and equivalent speed at a fraction of the power. The MAX912 dual comparator has equal performance to the MAX913 and inc
