Datasheet MAX923ESA+ - Maxim Даташит ИС GENERAL PURPOSE COMP сдвоенный 12 мкс SOIC-8 — Даташит
Наименование модели: MAX923ESA+
![]() 64 предложений от 29 поставщиков Микросхема Компаратор, MAXIM INTEGRATED PRODUCTS MAX923ESA+ Analog Comparator, Low Voltage, Micropower, 2, 12µs, 2.5V to 11V, ± 1.25V to ± 5.5V,... | |||
MAX923ESA+ Maxim | 420 ₽ | ||
MAX923ESA+ Maxim | 880 ₽ | ||
MAX923ESA+T Maxim | от 1 850 ₽ | ||
MAX923ESA+ Analog Devices | по запросу |
Производитель: Maxim
Описание: ИС GENERAL PURPOSE COMP сдвоенный 12 мкс SOIC-8
19-0115; Rev 6; 4/09
Ultra Low-Power, Single/Dual-Supply Comparators
_______________General Description
The MAX921MAX924 single, dual, and quad micropower, low-voltage comparators feature the lowest power consumption available.
These comparators draw less than 4µA supply current over temperature (MAX921/MAX922), and include an internal 1.182V ±1% voltage reference, programmable hysteresis, and TTL/CMOS outputs that sink and source current. Ideal for 3V or 5V single-supply applications, the MAX921MAX924 operate from a single +2.5V to +11V supply (or a ±1.25V to ±5V dual supply), and each comparator's input voltage range swings from the negative supply rail to within 1.3V of the positive supply. The MAX921MAX924's unique output stage continuously sources as much as 40mA. And by eliminating power-supply glitches that commonly occur when comparators change logic states, the MAX921MAX924 minimize parasitic feedback, which makes them easier to use. The single MAX921 and dual MAX923 prov
- Тип компаратора: General Purpose
- Количество компараторов: 2
- Время отклика: 12 мкс
- Тип выхода: CMOS, TTL
- Ток потребления: 3.1 мкА
- Диапазон напряжения питания: ± 1.25 В ... ± 5.5 В
- Тип корпуса: SOIC
