Datasheet MAX931CUA+ - Maxim Даташит ИС, GEN PUR COMP, одиночный, 12 мкс, ?MAX-8 — Даташит
Maxim MAX931CUA+
Наименование модели: MAX931CUA+
35 предложений от 18 поставщиков
Микросхема Компаратор, MAXIM INTEGRATED PRODUCTS MAX931CUA+ Analog Comparator, Low Voltage, Micropower, 1, 12µs, 2.5V to 11V, ± 1.25V to ± 5.5V,...
MAX931CUA+T
Maxim
84 ₽
MAX931CUA
Maxim
112 ₽
Hi-Tech Circuit Group
MAX931CUA+TG002
МосЧип
MAX931CUA
Maxim
Производитель: Maxim
Описание: ИС, GEN PUR COMP, одиночный, 12 мкс, ?MAX-8
data sheetСкачать Data Sheet
19-0194; Rev 1; 2/97
Ultra Low-Power, Low-Cost Comparators with 2% Reference
_______________General Description
The MAX931-MAX934 single, dual, and quad micropower, low-voltage comparators plus an on-board 2% accurate reference feature the lowest power consumption available.
These comparators draw less than 4µA supply current over temperature (MAX931), and include an internal 1.182V ±2% voltage reference, programmable hysteresis, and TTL/CMOS outputs that sink and source current. Ideal for 3V or 5V single-supply applications, the MAX931-MAX934 operate from a single +2.5V to +11V supply (or a ±1.25V to ±5V dual supply), and each comparator's input voltage range extends from the negative supply rail to within 1.3V of the positive supply. The MAX931-MAX934's unique output stage continuously sources as much as 40mA. And by eliminating powersupply glitches that commonly occur when comparators change logic states, the MAX931-MAX934 minimize parasitic feedback, which makes them easier to use
  • Тип компаратора: General Purpose
  • Количество компараторов: 1
  • Время отклика: 12 мкс
  • Тип выхода: CMOS, TTL
  • Ток потребления: 2.5 мкА
  • Диапазон напряжения питания: ± 1.25 В ... ± 5.5 В
  • Тип корпуса: µMAX
На английском языке: Datasheet MAX931CUA+ - Maxim IC, GEN PUR COMP, SINGLE, 12 µs, ?MAX-8
