Datasheet MAX2067ETL+ - Maxim Даташит ИС, VARIABLE GAIN усилитель, QFN-40 — Даташит
Наименование модели: MAX2067ETL+
23 предложений от 13 поставщиков
Усилитель IC и модуль RF, Analog Controlled VGA 40Pin TQFN EP T/R
MAX2067ETL+
Maxim
от 740 ₽
MAX2067ETL+T
Maxim
788 ₽
Эиком
MAX2067ETL+
от 2 724 ₽
MAX2067ETL
Maxim
Производитель: Maxim
Описание: ИС, VARIABLE GAIN усилитель, QFN-40
data sheetСкачать Data Sheet
19-4080; Rev 0; 4/08
50MHz to 1000MHz High-Linearity, Serial/Analog-Controlled VGA
General Description
The MAX2067 high-linearity analog variable-gain amplifier (VGA) is a monolithic SiGe BiCMOS attenuator and amplifier designed to interface with 50 systems operating in the 50MHz to 1000MHz frequency range (see the Typical Application Circuit).
The analog attenuator is controlled using an external voltage or through the SPITM-compatible interface using an on-chip 8-bit DAC. Because each stage has its own RF input and RF output, this component can be configured to either optimize NF (amplifier configured first), or OIP3 (amplifier last). The device's performance features include 22dB amplifier gain (amplifier only), 4dB NF at maximum gain (includes attenuator insertion loss), and a high OIP3 level of +43dBm. Each of these features makes the MAX2067 an ideal VGA for numerous receiver and transmitter applications. In addition, the MAX2067 operates from a single +5V supply with full perfo
  • Количество усилителей: 1
  • Полоса частот: 100 МГц
  • Количество каналов: 1
  • Диапазон напряжения питания: 3 В ... 3.6 В, 4.75 В ... 5.25 В
  • Тип корпуса: TQFN
  • Количество выводов: 40
  • Рабочий диапазон температрур: -40°C ... +85°C
На английском языке: Datasheet MAX2067ETL+ - Maxim IC, VARIABLE GAIN AMPLIFIER, QFN-40
