Datasheet MAX17535ETG+ - Maxim Даташит ИС, зарядное устройство батареи аккумуляторов, LI-ION, 7 А, TQFN-24 — Даташит
Наименование модели: MAX17535ETG+
14 предложений от 12 поставщиков
Микросхема Чип управления батареи, Battery Charger Li-Ion 7mA 24Pin TQFN EP T/R
MAX17535ETG+T
Maxim
407 ₽
MAX17535ETG+
Maxim
674 ₽
MAX17535ETG+T
Maxim
ЗУМ-СМД
MAX17535ETG
Maxim
Производитель: Maxim
Описание: ИС, зарядное устройство батареи аккумуляторов, LI-ION, 7 А, TQFN-24
data sheetСкачать Data Sheet
19-4817; Rev 1; 9/10
TION KIT EVALUA ILABLE AVA
High-Frequency, Low-Cost SMBus Chargers
Features
S S S S Low-Cost SMBus Charger High Switching Frequency (0.85MHz/0.5MHz) Internal Boost Switches SMBus-Programmable Charge Voltage, Input Current Limit, Charge Current, Relearn Voltage, and Digital IINP Readback Single-Point Compensation Automatic Selection of System Power Source Adapter n-Channel MOSFETs Driven by an Internal Dedicated Charge Pump Adapter Soft-Start ±0.4% Accurate Charge Voltage ±2.5% Accurate Input Current Limiting ±3% Accurate Charge Current Monitor Outputs for AC Adapter Current (±2% Accuracy) Battery Discharge Current (±2% Accuracy) AC Adapter Presence AC Adapter Overvoltage Protection 11-Bit Battery Voltage Setting 6-Bit, Charge-Current Setting/Input Current Setting Improved IINP Accuracy at Low Input Current
  • Battery Type: Li-Ion
  • Входное напряжение: 24 В
  • Battery Charge Voltage: 16.87 В
  • Charge Current Max: 7 А
  • Battery IC Case Style: TQFN
  • Количество выводов: 24
  • Number of Series Cells: 4
На английском языке: Datasheet MAX17535ETG+ - Maxim IC, BATTERY CHARGER, LI-ION, 7 A, TQFN-24
