Datasheet SSM2301RMZ-REEL7 - Analog Devices Даташит Усилитель, аудио, 1.52 Вт, моно, D, 8MSOP — Даташит
Наименование модели: SSM2301RMZ-REEL7
|  Купить SSM2301RMZ-REEL7 на РадиоЛоцман.Цены — от 43 до 566 ₽ 15 предложений от 14 поставщиков Микросхема Усилитель звуковой частоты, ANALOG DEVICES SSM2301RMZ-REEL7 Audio Power Amplifier, D, 1Channel, 1.4W, 2.5V to 5V, MSOP, 8Pins | |||
| SSM2301RMZ-REEL7 Analog Devices | 322 ₽ | ||
| SSM2301RMZ-REEL7 Analog Devices | по запросу | ||
| SSM2301RMZ-REEL7 Rochester Electronics | по запросу | ||
Производитель: Analog Devices
Описание: Усилитель, аудио, 1.52 Вт, моно, D, 8MSOP
Filterless High Efficiency Mono 1.4 W Class-D Audio Amplifier SSM2301
FEATURES
Filterless Class-D amplifier with - modulation No sync necessary when using multiple Class-D amplifiers from Analog Devices, Inc.
1.4 W into 8  at 5.0 V supply with less than 1% THD + N 85% efficiency at 5.0 V, 1.4 W into 8  speaker Greater than 98 dB SNR (signal-to-noise ratio) Single-supply operation from 2.5 V to 5.0 V 20 nA ultralow shutdown current Short-circuit and thermal protection Available in 8-lead, 3 mm Ч 3 mm LFCSP and MSOP packages Pop-and-click suppression Built-in resistors reduce board component count Fixed and user-adjustable gain configurations
The SSM2301 operates with 85% efficiency at 1.4 W into 8  from a 5.0 V supply and has a signal-to-noise ratio (SNR) that is greater than 98 dB. Spread-spectrum modulation is used to provide lower EMI-radiated emissions compared with other Class-D architectures. The SSM2301 has a micropower shutdown mode with a maximum shutdown current of 30 nA. Shu
- Класс усилителя: D
- Количество каналов: 1
- Выходная мощность: 1.4 Вт
- Диапазон напряжения питания: 2.5 В ... 5 В
- THD + N: 0.1% @ 1 Вт, 8 Ом, VDD=5V
- Load Impedance: 8 Ом
- Рабочий диапазон температрур: -40°C ... +85°C
- Тип корпуса: MSOP
- Количество выводов: 8
- Влагостойкость: MSL 1 - Unlimited
SSM2301RMZREEL7, SSM2301RMZ REEL7
 Скачать Data Sheet
Скачать Data Sheet
