Компактное аудиорешение Nuvoton NSP2340BA24E
Datasheet SSM2305RMZ-R2 - Analog Devices Даташит Усилитель, аудио, 2.8 Вт, моно, D, 8MSOP — Даташит
Analog Devices SSM2305RMZ-R2
Наименование модели: SSM2305RMZ-R2
Производитель: Analog Devices
Описание: Усилитель, аудио, 2.8 Вт, моно, D, 8MSOP
data sheetСкачать Data Sheet
Filterless High Efficiency Mono 2.8 W Class-D Audio Amplifier SSM2305
FEATURES
Filterless Class-D amplifier with - modulation No sync necessary when using multiple Class-D amplifiers from Analog Devices, Inc.
2.8 W into 4 load and 1.6 W into 8 load at 5.0 V supply with <10% total harmonic distortion (THD) 89% efficiency at 5.0 V, 1.3 W into 8 speaker >98 dB signal-to-noise ratio (SNR) Single-supply operation from 2.5 V to 5.5 V 20 nA ultralow shutdown current Short-circuit and thermal protection Available in 8-lead, 3 mm Ч 3 mm LFCSP and MSOP Pop-and-click suppression Built-in resistors reduce board component count Fixed and user-adjustable gain configurations
The SSM2305 features a high efficiency, low noise modulation scheme that does not require external LC output filters. The modulation provides high efficiency even at low output power. The SSM2305 operates with 90% efficiency at 1.3 W into 8 or 83% efficiency at 2.2 W into 4 from a 5.0 V supply and has an SNR of >98 dB. Spre
  • Класс усилителя: D
  • Количество каналов: 1
  • Выходная мощность: 2.8 Вт
  • Диапазон напряжения питания: 2.5 В ... 5.5 В
  • THD + N: 0.02% @ 1 Вт, 8 Ом, VDD=5V
  • Load Impedance: 4 Ом
  • Рабочий диапазон температрур: -40°C ... +85°C
  • Тип корпуса: MSOP
  • Количество выводов: 8
  • Влагостойкость: MSL 1 - Unlimited
SSM2305RMZR2, SSM2305RMZ R2
На английском языке: Datasheet SSM2305RMZ-R2 - Analog Devices AMP, AUDIO, 2.8 W, MONO, D, 8MSOP
Политика конфиденциальности
