Datasheet DTC144EET1G - ON Semiconductor Даташит Транзистор, цифровой — Даташит
ON Semiconductor DTC144EET1G
Наименование модели: DTC144EET1G
59 предложений от 22 поставщиков
Дискретные полупроводники Транзисторы — биполярные — одиночные, предсмещённые
727GS
DTC144EET1G
905 ₽
Hi-Tech Circuit Group
DTC144EET1G
TradeElectronics
DTC144EET1G/8C
LifeElectronics
DTC144EET1G
Производитель: ON Semiconductor
Описание: Транзистор, цифровой
data sheetСкачать Data Sheet
DTC114EET1 Series Bias Resistor Transistor
NPN Silicon Surface Mount Transistor with Monolithic Bias Resistor Network
This new series of digital transistors is designed to replace a single device and its external resistor bias network.
The BRT (Bias Resistor Transistor) contains a single transistor with a monolithic bias network consisting of two resistors; a series base resistor and a base-emitter resistor. The BRT eliminates these individual components by integrating them into a single device. The use of a BRT can reduce both system cost and board space. The device is housed in the SC-75/SOT-416 package which is designed for low power surface mount applications.
Features http://onsemi.com
NPN SILICON BIAS RESISTOR TRANSISTORS
  • Collector Emitter Voltage V(br)ceo: 50 В
  • Корпус транзистора: SC-75
  • Количество выводов: 3
  • SVHC: No SVHC (19-Dec-2011)
  • Base Input Resistor R1: 47 кОм
  • Base-Emitter Resistor R2: 47 кОм
  • Ток коллектора постоянный максимальный: 100 мА
  • Тип корпуса: SC-75
  • RF Transistor Case: SC-75
  • Resistor Ratio, R1 / R2: 1
  • Способ монтажа: SMD
  • Тип транзистора: Bias Resistor (BRT)
На английском языке: Datasheet DTC144EET1G - ON Semiconductor TRANSISTOR, DIGITAL
