Datasheet LPC1765FET100,551 - NXP Даташит 8- бит микроконтроллеры (MCU) CORTEX-M3 256 Кб FL 64 Кб SRAM USB 2.0 — Даташит
Наименование модели: LPC1765FET100,551
IC MCU 32BIT 256KB FLASH 100BGA. ARM® Cortex®-M3 LPC17xx Microcontroller IC 32-Bit 100MHz 256KB (256K x 8) FLASH 100-TFBGA (9x9). Embedded...
Рутоника
LPC1765FET100,551
420 ₽
TradeElectronics
LPC1765FET100,551
727GS
LPC1765FET100,551
LPC1765FET100,551
Производитель: NXP
Описание: 8- бит микроконтроллеры (MCU) CORTEX-M3 256 Кб FL 64 Кб SRAM USB 2.0
data sheetСкачать Data Sheet
LPC1769/68/67/66/65/64/63
32-bit ARM Cortex-M3 microcontroller; up to 512 kB flash and 64 kB SRAM with Ethernet, USB 2.0 Host/Device/OTG, CAN
Rev.
8 -- 14 November 2011 Product data sheet
1. General description
The LPC1769/68/67/66/65/64/63 are ARM Cortex-M3 based microcontrollers for embedded applications featuring a high level of integration and low power consumption. The ARM Cortex-M3 is a next generation core that offers system enhancements such as enhanced debug features and a higher level of support block integration. The LPC1768/67/66/65/64/63 operate at CPU frequencies of up to 100 MHz. The LPC1769 operates at CPU frequencies of up to 120 MHz. The ARM Cortex-M3 CPU incorporates a 3-stage pipeline and uses a Harvard architecture with separate local instruction and data buses as well as a third bus for peripherals. The ARM Cortex-M3 CPU also includes an internal prefetch unit that supports speculative branching. The peripheral complement of the LPC1769/68/67/66/65/64/63 includes
  • Упаковка: Tray
  • RoHS: да
LPC1765FET100551, LPC1765FET100 551
На английском языке: Datasheet LPC1765FET100,551 - NXP 8- bit Microcontrollers (MCU) CORTEX-M3 256 Kb FL 64 Kb SRAM USB 2.0
