Клеммные колодки Keen Side
Datasheet LPC2478FET208,551 - NXP Даташит ARM микроконтроллеры (MCU) жки CONT/ETHNET USB/512K FL — Даташит
NXP LPC2478FET208,551
Наименование модели: LPC2478FET208,551
31 предложений от 16 поставщиков
Микросхема Микроконтроллер, Single-chip 16Bit/32Bit micro; 512KB flash, Ethernet, CAN, LCD, USB 2.0 device/host/OTG, external memory interface
LPC2478FET208,551
776 ₽
T-electron
LPC2478FET208.551
1 406 ₽
LPC2478FET208,551
от 1 934 ₽
LPC2478FET208,551
Производитель: NXP
Описание: ARM микроконтроллеры (MCU) жки CONT/ETHNET USB/512K FL
data sheetСкачать Data Sheet
LPC2478
Single-chip 16-bit/32-bit micro; 512 kB flash, Ethernet, CAN, LCD, USB 2.0 device/host/OTG, external memory interface
Rev.
3 -- 12 September 2011 Product data sheet
1. General description
NXP Semiconductors designed the LPC2478 microcontroller, powered by the ARM7TDMI-S core, to be a highly integrated microcontroller for a wide range of applications that require advanced communications and high quality graphic displays. The LPC2478 microcontroller has 512 kB of on-chip high-speed flash memory. This flash memory includes a special 128-bit wide memory interface and accelerator architecture that enables the CPU to execute sequential instructions from flash memory at the maximum 72 MHz system clock rate. This feature is available only on the LPC2000 ARM microcontroller family of products. The LPC2478, with real-time debug interfaces that include both JTAG and embedded trace, can execute both 32-bit ARM and 16-bit Thumb instructions. The LPC2478 microcontroller incorporates an LCD
  • On-Chip DAC: да
  • Supply Voltage - Max: 3.6 В
  • Supply Voltage - Min: 3 В
  • Вид монтажа: SMD/SMT
  • Встроенный в чип АЦП: да
  • Высота: 0.8 мм (Max)
  • Длина: 15.1 мм (Max)
  • Интерфейс: CAN, I2C, I2S, IrDA, SPI, SSP, UART, USB
  • Количество линий ввода/вывода: 160
  • Количество таймеров: 4
  • Рабочее напряжение питания: 3.3 В
  • Размер ОЗУ: 98 Кб
  • Размер памяти программ: 512 Кб
  • Серия процессора: LPC24
  • Тактовая частота максимальная: 72 МГц
  • Тип корпуса: TFBGA
  • Тип памяти программ: Flash
  • Упаковка: Tray
  • Шина данных: 16 bit/32 бит
  • Ширина: 15.1 мм (Max)
  • Ядро: ARM7TDMI-S
  • RoHS: да
  • Другие названия товара: LPC2478FET208-S
LPC2478FET208551, LPC2478FET208 551
На английском языке: Datasheet LPC2478FET208,551 - NXP ARM Microcontrollers (MCU) LCD CONT/ETHNET USB/512K FL
