Datasheet G6AK-234P 24DC - Omron Даташит Реле, 3 А, 24 В постоянный ток — Даташит
Наименование модели: G6AK-234P 24DC
Купить G6AK-234P 24DC на РадиоЛоцман.Цены — от 234 до 277 ₽ Промышленные/Универсальные Реле, Electromechanical Relay DPDT 2A 24VDC 3200Ω Through Hole | |||
G6AK-234P-24DC Omron | 234 ₽ | ||
G6AK-234P-24DC Omron | 277 ₽ |
Производитель: Omron
Описание: Реле, 3 А, 24 В постоянный ток
Low Signal Relay
G6A
Fullly Sealed Relay with High Impulse Withstand
· High sensitivity -- can be driven by digital circuits.
· Low-profile design allows use in 12.70 mm PC board rack. · Surge withstand voltage meets FCC Part 68 regulation. · Units can be mounted side by side due to low magnetic leakage. · Special models available for low thermoelectromotive force. · Unique moving loop (permanent magnet) armature reduces relay size, magnetic interference, and contact bounce time. · Single or dual coil winding types available. · RoHS Compliant
RC FCC
G6AK234P 24DC, G6AK 234P 24DC
