Datasheet G7L-2A-P 100DC - Omron Даташит Реле, PCB, DPST-NO, 20 А, 100 В постоянный ток — Даташит
Omron G7L-2A-P 100DC
Наименование модели: G7L-2A-P 100DC
36 предложений от 22 поставщиков
Реле Мощности, Electromechanical Relay 24VDC 303Ω 20A DPST-NO (( 52.5mm 35.5mm 41mm)) THT General Purpose Relay
G7L-2A-P-CB-DC24
Omron
253 ₽
G7L-2A-P-PV24DC
Omron
583 ₽
G7L-2A-P-CB AC12
Omron
858 ₽
ТаймЧипс
G7L-2A-P-CB DC6
Omron
Производитель: Omron
Описание: Реле, PCB, DPST-NO, 20 А, 100 В постоянный ток
data sheetСкачать Data Sheet
G7L
· Ideally suited for high-inrush fluid pump controls: pool/spa, water processing, emergency, chemical industry, etc.
· High-capacity, high-withstand voltage relay with no contact chattering for momentary voltage drops up to 50% of rated voltage. · UL Class B construction standard. · Wide-range AC-activated coil that handles 100 to 120 VAC at either 50 or 60 Hz. · Miniature hinge for maximum switching capacity, particularly for inductive loads. · Flame resistant materials (UL94V-0-qualifying) used for all insulation material. · Quick-connect, screw, and PCB terminals available. · Standard models are UL, CSA, and TUV approved; VDE/IEC 950 versions are now available. Meet pollution degree 3, Material Group II & III.
Ordering Information
To Order: Select the part number and add the desired coil voltage rating (e.g., G7L-1A-T-CB-AC100/120). Type E bracket (see note 1) E bracket (see note 1) (with test button) Upper bracket Upper bracket (with test button) PCB mou
  • Coil Current: 19 мА
  • Coil Resistance: 5.26 кОм
  • Coil Type: DC
  • Coil Voltage VDC Nom: 100 В
  • Contact Current Max: 20 А
  • External Depth: 52.5 мм
  • Operating Power Nom: 1.9 Вт
  • Внешняя ширина: 35.5 мм
  • Габариты: высота: 41 мм
  • Конфигурация контактов: DPST-NO
  • Способ монтажа: PCB
  • Тип реле: General Purpose
  • RoHS: да
  • SVHC: No SVHC (19-Dec-2011)
G7L2AP 100DC, G7L 2A P 100DC
На английском языке: Datasheet G7L-2A-P 100DC - Omron RELAY, PCB, DPST-NO, 20 A, 100 V DC
