Datasheet G7L-2A-T AC12 - Omron Даташит Реле, QC, DPST-NO, 20 А, 12 VAC — Даташит
Наименование модели: G7L-2A-T AC12
 Купить G7L-2A-T AC12 на РадиоЛоцман.Цены — от 868 до 2 625 ₽Несгруппированные, Relay; E-Mech; DPST-NO; Ctrl-V 12AC; 25A; 250VAC; Bracket Mount; QC Terminal; G7L Series  | |||
| G7L2ATAC12 Omron  | 868 ₽ | ||
| G7L2ATAC12 Omron  | 1 210 ₽ | ||
| G7L-2A-T-AC12 Omron  | 2 625 ₽ | ||
Производитель: Omron
Описание: Реле, QC, DPST-NO, 20 А, 12 VAC
General Purpose Relay
G7L
· Ideally suited for high-inrush fluid pump controls: pool/spa, water processing, emergency, chemical industry, etc.
· High-capacity, high-withstand voltage relay with no contact chattering for momentary voltage drops up to 50% of rated voltage. · UL Class B construction standard. · Wide-range AC-activated coil that handles 100 to 120 VAC at either 50 or 60 Hz. · Miniature hinge for maximum switching capacity, particularly for inductive loads. · Flame resistant materials (UL94V-0-qualifying) used for all insulation material. · Quick-connect, screw, and PCB terminals available. · Standard models are UL, CSA, and TUV approved; VDE/IEC 950 versions are now available. Meet pollution degree 3, Material Group II & III.
Ordering Information
To Order: Select the part number and add the desired coil voltage rating (e.g., G7L-1A-T-CB-AC100/120). Type E bracket (see note 1) E bracket (see note 1) (with test button) Upper bracket Upper bracket (with test button) PCB mou
- Тип реле: General Purpose
 - Coil Voltage VAC Nom: 12 В
 - Contact Current Max: 25 А
 - Coil Resistance: 75 Ом
 - Конфигурация контактов: DPST-NO
 - Coil Type: AC
 - Coil Current: 142 мА
 - Operating Power Nom: 2.5 VA
 - Способ монтажа: Panel
 - Габариты: высота: 53 мм
 - Внешняя ширина: 33.5 мм
 - External Depth: 52.5 мм
 - SVHC: No SVHC (20-Jun-2011)
G7L2AT AC12, G7L 2A T AC12
