Datasheet G7L-2A-TUB 24AC - Omron Даташит Реле, BRACKET, DPST-NO, 20 А, 24 VAC — Даташит
Наименование модели: G7L-2A-TUB 24AC
Промышленные/Универсальные Реле, Electromechanical Relay 24VAC 25A DPST-NO (68.5x33.5x47)mm Bracket Power Relay | |||
G7L2ATUB24AC Omron | 633 ₽ | ||
G7L-2A-TUB24AC Omron | по запросу |
Производитель: Omron
Описание: Реле, BRACKET, DPST-NO, 20 А, 24 VAC
General Purpose Relay
G7L
· Ideally suited for high-inrush fluid pump controls: pool/spa, water processing, emergency, chemical industry, etc.
· High-capacity, high-withstand voltage relay with no contact chattering for momentary voltage drops up to 50% of rated voltage. · UL Class B construction standard. · Wide-range AC-activated coil that handles 100 to 120 VAC at either 50 or 60 Hz. · Miniature hinge for maximum switching capacity, particularly for inductive loads. · Flame resistant materials (UL94V-0-qualifying) used for all insulation material. · Quick-connect, screw, and PCB terminals available. · Standard models are UL, CSA, and TUV approved; VDE/IEC 950 versions are now available. Meet pollution degree 3, Material Group II & III.
Ordering Information
To Order: Select the part number and add the desired coil voltage rating (e.g., G7L-1A-T-CB-AC100/120). Type E bracket (see note 1) E bracket (see note 1) (with test button) Upper bracket Upper bracket (with test button) PCB mou
- Тип реле: General Purpose
- Coil Voltage VAC Nom: 24 В
- Contact Current Max: 25 А
- Coil Resistance: 303 Ом
- Конфигурация контактов: DPST-NO
- Coil Type: AC
- Coil Current: 71 мА
- Operating Power Nom: 2.5 VA
- Способ монтажа: Panel
- Габариты: высота: 47 мм
- Внешняя ширина: 33.5 мм
- External Depth: 50.5 мм
- SVHC: No SVHC (20-Jun-2011)
G7L2ATUB 24AC, G7L 2A TUB 24AC
