Datasheet G7L-2A-TUB DC100 - Omron Даташит Реле, BRACKET, DPST-NO, 20 А, 100 В постоянный ток — Даташит
Наименование модели: G7L-2A-TUB DC100
![]() Несгруппированные, Relay; E-Mech; DPST-NO; Ctrl-V 100DC; 25A; 250VAC; Panel Mount; QC Terminal; G7L Series | |||
G7L2ATUBDC100 Omron | 997 ₽ | ||
G7L2ATUBDC100 Omron | 1 475 ₽ |
Производитель: Omron
Описание: Реле, BRACKET, DPST-NO, 20 А, 100 В постоянный ток
General Purpose Relay
G7L
· Ideally suited for high-inrush fluid pump controls: pool/spa, water processing, emergency, chemical industry, etc.
· High-capacity, high-withstand voltage relay with no contact chattering for momentary voltage drops up to 50% of rated voltage. · UL Class B construction standard. · Wide-range AC-activated coil that handles 100 to 120 VAC at either 50 or 60 Hz. · Miniature hinge for maximum switching capacity, particularly for inductive loads. · Flame resistant materials (UL94V-0-qualifying) used for all insulation material. · Quick-connect, screw, and PCB terminals available. · Standard models are UL, CSA, and TUV approved; VDE/IEC 950 versions are now available. Meet pollution degree 3, Material Group II & III.
Ordering Information
To Order: Select the part number and add the desired coil voltage rating (e.g., G7L-1A-T-CB-AC100/120). Type E bracket (see note 1) E bracket (see note 1) (with test button) Upper bracket Upper bracket (with test button) PCB mou
- Тип реле: General Purpose
- Coil Voltage VDC Nom: 100 В
- Contact Current Max: 25 А
- Coil Resistance: 5.26 кОм
- Конфигурация контактов: DPST-NO
- Coil Type: DC
- Coil Current: 19 мА
- Operating Power Nom: 1.9 Вт
- Способ монтажа: Panel
- Габариты: высота: 47 мм
- Внешняя ширина: 33.5 мм
- External Depth: 50.5 мм
- SVHC: No SVHC (20-Jun-2011)
G7L2ATUB DC100, G7L 2A TUB DC100
