Datasheet G9EA-1 DC100 - Omron Даташит Реле, SPST-NO, 60 А, LEADS, 100 В постоянный ток — Даташит
Omron G9EA-1 DC100
Наименование модели: G9EA-1 DC100
5 предложений от 5 поставщиков
, Power Relay 100VDC 100A SPST-NO(73x36x67.2)mm Flange
G9EA-1-DC100
Omron
10 514 ₽
G9EA-1-DC100
Omron
14 629 ₽
Элитан
G9EA-1-DC100
Omron
41 864 ₽
LifeElectronics
G9EA1DC100
Производитель: Omron
Описание: Реле, SPST-NO, 60 А, LEADS, 100 В постоянный ток
data sheetСкачать Data Sheet
DC Power Relays (60-A, 100-A Models)
G9EA-1
DC Power Relays Capable of Interrupting Highvoltage, High-current Loads
· A compact relay capable of switching 400-V 60-A/100-A DC loads.
(Capable of interrupting 600 A at 300 VDC max.) · The switching section and driving section are gas-injected and hermetically sealed, allowing these compact relays to interrupt highcapacity loads. The sealed construction also requires no arc space, saves space, and helps ensure safe applications. · Downsizing and optimum design allow no restrictions on the mounting direction. · Terminal Cover and DIN Track Adapters are also available for industrial applications. · UL/CSA standard UL508 approved.
Model Number Structure
  • Тип реле: Power
  • Coil Voltage VDC Nom: 100 В
  • Contact Current Max: 60 А
  • Contact Voltage DC Nom: 400 В
  • Coil Resistance: 1.864 кОм
  • Конфигурация контактов: SPST-NO
  • Coil Type: DC
  • Coil Current: 53.6 мА
  • Operating Power Nom: 5.4 Вт
  • Способ монтажа: Screw
  • Габариты: высота: 67.2 мм
  • Внешняя ширина: 36 мм
  • External Depth: 73 мм
G9EA1 DC100, G9EA 1 DC100
На английском языке: Datasheet G9EA-1 DC100 - Omron RELAY, SPST-NO, 60 A, LEADS, 100 V DC
