Datasheet LPC1778FET180,551 - NXP Даташит 8- бит микроконтроллеры (MCU) CORTEX-M3 512 Кб FL 96 Кб SRAM USB 2.0 — Даташит
Наименование модели: LPC1778FET180,551
29 предложений от 15 поставщиков
Микросхема Микроконтроллер, MCU 32Bit ARM Cortex M3 RISC 512KB Flash 3.3V Automotive 180Pin TFBGA Tray
LPC1778FET180,551
414 ₽
LPC1778FET180,551
Nexperia
от 1 549 ₽
МосЧип
LPC1778FET180,551
LPC1778FET180551
Производитель: NXP
Описание: 8- бит микроконтроллеры (MCU) CORTEX-M3 512 Кб FL 96 Кб SRAM USB 2.0
data sheetСкачать Data Sheet
LPC178x/7x
32-bit ARM Cortex-M3 microcontroller; up to 512 kB flash and 96 kB SRAM; USB Device/Host/OTG; Ethernet; LCD; EMC
Rev.
3 -- 27 December 2011 Objective data sheet
1. General description
The LPC178x/7x is an ARM Cortex-M3 based microcontroller for embedded applications requiring a high level of integration and low power dissipation. The Cortex-M3 is a next generation core that offers better performance than the ARM7 at the same clock rate and other system enhancements such as modernized debug features and a higher level of support block integration. The Cortex-M3 CPU incorporates a 3-stage pipeline and has a Harvard architecture with separate local instruction and data buses, as well as a third bus with slightly lower performance for peripherals. The Cortex-M3 CPU also includes an internal prefetch unit that supports speculative branches. The LPC178x/7x adds a specialized flash memory accelerator to accomplish optimal performance when executing code from flash. The LPC178x/7x
  • Упаковка: Tray
  • RoHS: да
LPC1778FET180551, LPC1778FET180 551
На английском языке: Datasheet LPC1778FET180,551 - NXP 8- bit Microcontrollers (MCU) CORTEX-M3 512 Kb FL 96 Kb SRAM USB 2.0
