Datasheet AT87C58X2-SLRUM - Atmel Даташит Микроконтроллеры (MCU) 32K 40 МГц — Даташит
Наименование модели: AT87C58X2-SLRUM
7 предложений от 7 поставщиков new in stock for immediate delivery | |||
AT87C58X2-SLRUM Microchip | 64 ₽ | ||
AT87C58X2-SLRUM Microchip | по запросу | ||
Производитель: Atmel
Описание: Микроконтроллеры (MCU) 32K 40 МГц
Features
80C52 Compatible 8051 pin and instruction compatible Four 8-bit I/O ports Three 16-bit timer/counters 256 bytes scratchpad RAM High-Speed Architecture 40 MHz @ 5V, 30MHz @ 3V X2 Speed Improvement capability (6 clocks/machine cycle) 30 MHz @ 5V, 20 MHz @ 3V (Equivalent to 60 MHz @ 5V, 40 MHz @ 3V) Dual Data Pointer On-chip ROM/EPROM (16K-bytes, 32K-bytes) Programmable Clock Out and Up/Down Timer/Counter 2 Hardware Watchdog Timer (One-time enabled with Reset-Out) Asynchronous port reset Interrupt Structure with 6 Interrupt sources 4 level priority interrupt system Full duplex Enhanced UART Framing error detection Automatic address recognition Low EMI (inhibit ALE) Power Control modes Idle mode Power-down mode Power-off Flag Once mode (On-chip Emulation) Power supply: 4.5-5.5V, 2.7-5.5V Temperature ranges: Commercial (0 to 70oC) and Industrial (-40 to 85 oC) Packages: PDIL40, PLCC44, VQFP44 1.4, PQFP44 F1, CQPJ44 (window), CDIL40 (window)
- Вид монтажа: SMD/SMT
- Тип корпуса: PLCC-44
- Шина данных: 8 бит
- Норма фабричной упаковки: 500
AT87C58X2SLRUM, AT87C58X2 SLRUM
