Datasheet ATMEGA162-W-11 - Atmel Даташит Микроконтроллеры (MCU) AVR 16K FLASH 512B EE 1K SRAM — Даташит
Наименование модели: ATMEGA162-W-11
8-bit Microcontroller with 16K Bytes In-System Programmable Flash | |||
ATMEGA162-W-7 Atmel | по запросу |
Производитель: Atmel
Описание: Микроконтроллеры (MCU) AVR 16K FLASH 512B EE 1K SRAM
Features
· High-performance, Low-power AVR® 8-bit Microcontroller · Advanced RISC Architecture
131 Powerful Instructions Most Single-clock Cycle Execution 32 x 8 General Purpose Working Registers Fully Static Operation Up to 16 MIPS Throughput at 16 MHz On-chip 2-cycle Multiplier High Endurance Non-volatile Memory segments 16K Bytes of In-System Self-programmable Flash program memory 512 Bytes EEPROM 1K Bytes Internal SRAM Write/Erase cycles: 10,000 Flash/100,000 EEPROM Data retention: 20 years at 85°C/100 years at 25°C(1) Optional Boot Code Section with Independent Lock Bits In-System Programming by On-chip Boot Program True Read-While-Write Operation Up to 64K Bytes Optional External Memory Space Programming Lock for Software Security JTAG (IEEE std.
1149.1 Compliant) Interface Boundary-scan Capabilities According to the JTAG Standard Extensive On-chip Debug Support Programming of Flash, EEPROM, Fuses, and Lock Bits through the JTAG Interface Periphe
- Размер ОЗУ: 1 Кб
- Размер ПЗУ данных: 512 B
- Размер памяти программ: 16 Кб
- Тип памяти программ: Flash
- Шина данных: 8 бит
- RoHS: нет
ATMEGA162W11, ATMEGA162 W 11
