Datasheet MAX2251EVKIT - Maxim Даташит Микроконтроллеры (MCU) — Даташит
Наименование модели: MAX2251EVKIT
Радиочастотные средства разработки
MAX2251EVKIT
LifeElectronics
MAX2251EVKIT
Maxim
Производитель: Maxim
Описание: Микроконтроллеры (MCU)
data sheetСкачать Data Sheet
19-1773; Rev 1; 11/00
MAX2251 Evaluation Kit
General Description
The MAX2251 evaluation kit (EV kit) simplifies evaluation of the MAX2251 power amplifier (PA), which is designed for operation in IS-136-based TDMA and AMPS.
The kit enables testing of the device's RF performance and requires no additional support circuitry. The EV kit's signal input and output use SMA connectors to facilitate the connection of RF test equipment. Each kit is assembled with the MAX2251 and incorporates input and output matching components optimized for the 824MHz to 849MHz RF frequency band. The EV kit is capable of operating at RF frequencies from 750MHz to 1000MHz with the appropriate matching components. o Easy Evaluation of MAX2251 o +2.8V to +4.5V Single-Supply Operation o RF Input/Output Matched for 824MHz to 849MHz Operation o Fully Assembled and Tested
Features
На английском языке: Datasheet MAX2251EVKIT - Maxim Microcontrollers (MCU)
