Datasheet ATMEGA32L-W-11 - Atmel Даташит Микроконтроллеры (MCU) микроконтроллер — Даташит
Наименование модели: ATMEGA32L-W-11
![]() 59 предложений от 31 поставщиков 8- битный AVR RISC микроконтроллер (32K ISP Flash, 1K EEPROM, 2K SRAM, JTAG, 32x8 register, 2x8-bit/16-bit timer/counters, 4xPWM, 8-ch 10-bit ADC,... | |||
ATMEGA32L-8MC | 101 ₽ | ||
ATMEGA32L-8AU Rochester Electronics | от 375 ₽ | ||
ATMEGA32L-8PIPDIP40IND Atmel | по запросу | ||
ATMEGA32L LAPIS Semiconductor | по запросу |
Производитель: Atmel
Описание: Микроконтроллеры (MCU) микроконтроллер
Features
· High-performance, Low-power Atmel® AVR® 8-bit Microcontroller · Advanced RISC Architecture
131 Powerful Instructions Most Single-clock Cycle Execution 32 x 8 General Purpose Working Registers Fully Static Operation Up to 16 MIPS Throughput at 16 MHz On-chip 2-cycle Multiplier High Endurance Non-volatile Memory segments 32 Kbytes of In-System Self-programmable Flash program memory 1024 Bytes EEPROM 2 Kbyte Internal SRAM Write/Erase Cycles: 10,000 Flash/100,000 EEPROM Data retention: 20 years at 85°C/100 years at 25°C(1) Optional Boot Code Section with Independent Lock Bits In-System Programming by On-chip Boot Program True Read-While-Write Operation Programming Lock for Software Security JTAG (IEEE std.
1149.1 Compliant) Interface Boundary-scan Capabilities According to the JTAG Standard Extensive On-chip Debug Support Programming of Flash, EEPROM, Fuses, and Lock Bits through the JTAG Interface Peripheral Features Two 8-bit Timer/Counters wi
- Размер ОЗУ: 2 Кб
- Размер ПЗУ данных: 1024 B
- Тип памяти программ: Flash
- Шина данных: 8 бит
- RoHS: нет
ATMEGA32LW11, ATMEGA32L W 11
