Datasheet ATTINY5-MAH - Atmel Даташит Микроконтроллеры (MCU) 512B FL 32B SRAM ADC таймер ATTINY5 12 МГц — Даташит
Наименование модели: ATTINY5-MAH
![]() 7 предложений от 7 поставщиков Микросхема Микроконтроллер, IC MCU 8Bit 512B FLASH 8UDFN | |||
ATTINY5-MAH Microchip | 64 ₽ | ||
ATTINY5-MAH Atmel | 80 ₽ | ||
ATTINY5-MAH Microchip | по запросу | ||
ATTINY5-MAH Atmel | по запросу |
Производитель: Atmel
Описание: Микроконтроллеры (MCU) 512B FL 32B SRAM ADC таймер ATTINY5 12 МГц
Features
· High Performance, Low Power AVR® 8-Bit Microcontroller · Advanced RISC Architecture
54 Powerful Instructions Most Single Clock Cycle Execution 16 x 8 General Purpose Working Registers Fully Static Operation Up to 12 MIPS Throughput at 12 MHz Non-volatile Program and Data Memories 512/1024 Bytes of In-System Programmable Flash Program Memory 32 Bytes Internal SRAM Flash Write/Erase Cycles: 10,000 Data Retention: 20 Years at 85oC / 100 Years at 25oC Peripheral Features One 16-bit Timer/Counter with Prescaler and Two PWM Channels Programmable Watchdog Timer with Separate On-chip Oscillator 4-channel, 8-bit Analog to Digital Converter (1) On-chip Analog Comparator Special Microcontroller Features In-System Programmable (2) External and Internal Interrupt Sources Low Power Idle, ADC Noise Reduction, and Power-down Modes Enhanced Power-on Reset Circuit Programmable Supply Voltage Level Monitor with Interrupt and Reset Internal Calibrated Oscil
- Ядро: AVR8
- RoHS: да
ATTINY5MAH, ATTINY5 MAH
