Datasheet ATTINY9-MAH - Atmel Даташит Микроконтроллеры (MCU) 1 Кб FL 32B SRAM таймер ATTINY9 12 МГц — Даташит
Наименование модели: ATTINY9-MAH
 Купить ATTINY9-MAH на РадиоЛоцман.Цены — от 54 до 117 ₽12 предложений от 12 поставщиков IC MCU 8BIT 1KB FLASH 8UDFN. AVR AVR® ATtiny Microcontroller IC 8-Bit 12MHz 1KB (512 x 16) FLASH 8-UDFN, USON. Embedded...  | |||
| ATTINY9-MAH Microchip  | 58 ₽ | ||
| ATTINY9-MAH Rochester Electronics  | 62 ₽ | ||
| ATTINY9-MAH Microchip  | 65 ₽ | ||
| ATTINY9-MAH Atmel  | 81 ₽ | ||
Производитель: Atmel
Описание: Микроконтроллеры (MCU) 1 Кб FL 32B SRAM таймер ATTINY9 12 МГц
Features
· High Performance, Low Power AVR® 8-Bit Microcontroller · Advanced RISC Architecture
 54 Powerful Instructions  Most Single Clock Cycle Execution  16 x 8 General Purpose Working Registers  Fully Static Operation  Up to 12 MIPS Throughput at 12 MHz Non-volatile Program and Data Memories  512/1024 Bytes of In-System Programmable Flash Program Memory  32 Bytes Internal SRAM  Flash Write/Erase Cycles: 10,000  Data Retention: 20 Years at 85oC / 100 Years at 25oC Peripheral Features  One 16-bit Timer/Counter with Prescaler and Two PWM Channels  Programmable Watchdog Timer with Separate On-chip Oscillator  4-channel, 8-bit Analog to Digital Converter (1)  On-chip Analog Comparator Special Microcontroller Features  In-System Programmable (2)  External and Internal Interrupt Sources  Low Power Idle, ADC Noise Reduction, and Power-down Modes  Enhanced Power-on Reset Circuit  Programmable Supply Voltage Level Monitor with Interrupt and Reset  Internal Calibrated Oscil
- Ядро: AVR8
 - RoHS: да
ATTINY9MAH, ATTINY9 MAH
