Datasheet ATTINY4-MAH - Atmel Даташит Микроконтроллеры (MCU) 512B FL 32B SRAM таймер ATTINY4 12 МГц — Даташит
Наименование модели: ATTINY4-MAH
8-битные микроконтроллеры 512B FL 32B SRAM TIMER ATTINY4 12MHz
Элитан
ATTINY4-MAH
110 ₽
ATTINY4-MAH
ATTINY4-MAH
Atmel
Производитель: Atmel
Описание: Микроконтроллеры (MCU) 512B FL 32B SRAM таймер ATTINY4 12 МГц
data sheetСкачать Data Sheet
Features
· High Performance, Low Power AVR® 8-Bit Microcontroller · Advanced RISC Architecture
­ 54 Powerful Instructions ­ Most Single Clock Cycle Execution ­ 16 x 8 General Purpose Working Registers ­ Fully Static Operation ­ Up to 12 MIPS Throughput at 12 MHz Non-volatile Program and Data Memories ­ 512/1024 Bytes of In-System Programmable Flash Program Memory ­ 32 Bytes Internal SRAM ­ Flash Write/Erase Cycles: 10,000 ­ Data Retention: 20 Years at 85oC / 100 Years at 25oC Peripheral Features ­ One 16-bit Timer/Counter with Prescaler and Two PWM Channels ­ Programmable Watchdog Timer with Separate On-chip Oscillator ­ 4-channel, 8-bit Analog to Digital Converter (1) ­ On-chip Analog Comparator Special Microcontroller Features ­ In-System Programmable (2) ­ External and Internal Interrupt Sources ­ Low Power Idle, ADC Noise Reduction, and Power-down Modes ­ Enhanced Power-on Reset Circuit ­ Programmable Supply Voltage Level Monitor with Interrupt and Reset ­ Internal Calibrated Oscil
  • Ядро: AVR8
  • RoHS: да
ATTINY4MAH, ATTINY4 MAH
На английском языке: Datasheet ATTINY4-MAH - Atmel Microcontrollers (MCU) 512B FL 32B SRAM TIMER ATTINY4 12 MHz
