Datasheet AT80251G2D-SLRUM - Atmel Даташит Микроконтроллеры (MCU) ROMless 8/16 бит 5 В 24 МГц — Даташит
Наименование модели: AT80251G2D-SLRUM
Купить AT80251G2D-SLRUM на РадиоЛоцман.Цены — от 71 до 143 143 ₽ 12 предложений от 9 поставщиков C251 8x251 Microcontroller IC 8/16-Bit 24MHz ROMless 44-PLCC (16.6x16.6) | |||
AT80251G2D-SLRUM Microchip | 71 ₽ | ||
AT80251G2D-SLRUM Microchip | от 462 ₽ | ||
AT80251G2D-SLRUM Atmel | 513 ₽ | ||
AT80251G2DSLRUM | 143 143 ₽ |
Производитель: Atmel
Описание: Микроконтроллеры (MCU) ROMless 8/16 бит 5 В 24 МГц
Features
Pin and Software Compatibility with Standard 80C51 Products and 80C51Fx/Rx/Rx+ Plug-In Replacement of Intel's 8xC251Sx C251 Core: Intel's MCS®251 D-step Compliance 40-byte Register File Registers Accessible as Bytes, Words or Dwords Three-stage Instruction Pipeline 16-bit Internal Code Fetch Enriched C51 Instruction Set 16-bit and 32-bit ALU Compare and Conditional Jump Instructions Expanded Set of Move Instructions Linear Addressing 1 Kbyte of On-Chip RAM External Memory Space (Code/Data) Programmable from 64 kilobytes to 256 kilobytes TSC87251G2D: 32 kilobytes of On-Chip EPROM/OTPROM SINGLE PULSE Programming Algorithm TSC83251G2D: 32 kilobytes of On-Chip Masked ROM TSC80251G2D: ROMless Version Four 8-bit Parallel I/O Ports (Ports 0, 1, 2 and 3 of the Standard 80C51) Serial I/O Port: Full Duplex UART (80C51 Compatible) With Independent Baud Rate Generator SSLC: Synchronous Serial Link Controller TWI Multi-master Protocol
- Шина данных: 8 бит, 16 бит
- RoHS: да
AT80251G2DSLRUM, AT80251G2D SLRUM
