Datasheet ATMEGA16U2-16MU - Atmel Даташит Микроконтроллеры (MCU) 16K Flash — Даташит
Наименование модели: ATMEGA16U2-16MU
8-битные микроконтроллеры 16K Flash | |||
| ATMEGA16U2-16MU Atmel | по запросу | ||
Производитель: Atmel
Описание: Микроконтроллеры (MCU) 16K Flash
Features
· High Performance, Low Power AVR® 8-Bit Microcontroller · Advanced RISC Architecture
125 Powerful Instructions Most Single Clock Cycle Execution 32 x 8 General Purpose Working Registers Fully Static Operation Up to 16 MIPS Throughput at 16 MHz · Non-volatile Program and Data Memories 8K/16K/32K Bytes of In-System Self-Programmable Flash 512/512/1024 EEPROM 512/512/1024 Internal SRAM Write/Erase Cycles: 10,000 Flash/ 100,000 EEPROM Data retention: 20 years at 85°C/ 100 years at 25°C(1) Optional Boot Code Section with Independent Lock Bits In-System Programming by on-chip Boot Program hardware-activated after reset True Read-While-Write Operation Programming Lock for Software Security · USB 2.0 Full-speed Device Module with Interrupt on Transfer Completion Complies fully with Universal Serial Bus Specification REV 2.0 48 MHz PLL for Full-speed Bus Operation : data transfer rates at 12 Mbit/s Fully independant 176 bytes USB DPRAM for endpoint memory
- Размер ОЗУ: 1.25 Кб
- Размер ПЗУ данных: 512 B
- Размер памяти программ: 16 Кб
- Тип памяти программ: Flash
- Упаковка: Tray
- Шина данных: 8 бит
- RoHS: да
ATMEGA16U216MU, ATMEGA16U2 16MU
