Datasheet ATTINY10-MAH - Atmel Даташит Микроконтроллеры (MCU) AVR 1 Кб FL 32B SRAM ATTINY10 12 МГц — Даташит
Наименование модели: ATTINY10-MAH
Купить ATTINY10-MAH на РадиоЛоцман.Цены — от 22 до 117 ₽ 7 предложений от 7 поставщиков 8-битные микроконтроллеры AVR 1KB FL 32B SRAM ATTINY10 12MHz | |||
ATTINY10-MAH Atmel | 53 ₽ | ||
ATTINY10-MAH Atmel | 56 ₽ | ||
ATTINY10-MAH Microchip | 117 ₽ | ||
ATTINY10-MAH Microchip | по запросу |
Производитель: Atmel
Описание: Микроконтроллеры (MCU) AVR 1 Кб FL 32B SRAM ATTINY10 12 МГц
Features
· High Performance, Low Power AVR® 8-Bit Microcontroller · Advanced RISC Architecture
54 Powerful Instructions Most Single Clock Cycle Execution 16 x 8 General Purpose Working Registers Fully Static Operation Up to 12 MIPS Throughput at 12 MHz Non-volatile Program and Data Memories 512/1024 Bytes of In-System Programmable Flash Program Memory 32 Bytes Internal SRAM Flash Write/Erase Cycles: 10,000 Data Retention: 20 Years at 85oC / 100 Years at 25oC Peripheral Features One 16-bit Timer/Counter with Prescaler and Two PWM Channels Programmable Watchdog Timer with Separate On-chip Oscillator 4-channel, 8-bit Analog to Digital Converter (1) On-chip Analog Comparator Special Microcontroller Features In-System Programmable (2) External and Internal Interrupt Sources Low Power Idle, ADC Noise Reduction, and Power-down Modes Enhanced Power-on Reset Circuit Programmable Supply Voltage Level Monitor with Interrupt and Reset Internal Calibrated Oscil
- Ядро: AVR8
- RoHS: да
ATTINY10MAH, ATTINY10 MAH
