Datasheet Microchip PIC16LF1508T-I/SO — Даташит
СерияPIC16F1508
МодельPIC16LF1508T-I/SO
Debug Support • External debug header (AC244051/AC244052) is needed for debug support • Debug and Programming support is available via PICkit 3, and MPLAB ICD 3
PIC16(L)F1508/9 20-Pin Flash, 8-Bit MCU with XLP Technology
PDF, 4.0 Мб, Файл опубликован: 28 окт 2015
Микросхема Микроконтроллер, 8Bit Microcontrollers - MCU 7KB FLASH 256B RAM 18 I/O 10Bit ADC
PIC16LF1508T-I/SO
70 ₽
PIC16LF1508T-I/SO
103 ₽
PIC16LF1508T-I/SO
125 ₽
Hi-Tech Circuit Group
PIC16LF1508T-I/SO
КорпусSOIC
Количество выводов20
ADC Input12
ADC with ComputationNo
Angular TimerNo
Архитектура8
CPU Type8-bit PIC MCU
CRCNo
Class B HardwareNo
Configurable Logic Cell4 CLC/CCL
Emulated EEPROM in Flash0 / HEF
High Voltage CapableNo
I2C1
Internal Oscillator16 MHz, 32 kHz
Math AcceleratorNo
Max 16-Bit Digital Timers1
Max 8-Bit Digital Timers2
Max ADC Resolution10 Bits
Max CPU Speed20 МГц
Max DAC Resolution5 Bits
Max PWM outputs5 including complementary
Количество компараторов2
Number of DACs1
Numerically Controlled Oscillator1
Operation Voltage Max5.5 В
Operation Voltage Min1.8 В
PWM Max Resolution10 Bits
Peripheral Pin Select / Pin MuxingNo
Pin count20
Размер памяти программ7 KB
SPI1
SRAM256 Bytes
Temp Range Max125
Temp Range Min-40
UART1
Zero Cross detectNo
PIC16F1509
  • Microcontrollers > 8-bit Microcontrollers
PIC16LF1508TI/SO, PIC16LF1508T I/SO
На английском языке: Datasheet Microchip PIC16LF1508T-I/SO
