Datasheet QT60240-ATG - Atmel Даташит Микроконтроллеры (MCU) интегральная схема — Даташит
Наименование модели: QT60240-ATG
![]() 14 предложений от 11 поставщиков Ёмкостный тактильный датчик , ATMEL QT60240-ATG Capacitive Touch Sensor, I2C, 1.8V, 5.5V, QFN, 32Pins, -40℃ | |||
QT60240-ATG Atmel | от 552 ₽ | ||
QT60240-ATG Atmel | по запросу | ||
QT60240-ATG Microchip | по запросу | ||
Производитель: Atmel
Описание: Микроконтроллеры (MCU) интегральная схема
lQ
QT60160, QT60240
16 AND 24 KEY QMATRIXTM TOUCH SENSOR ICs
SCL /RST Y0A Y2B SMP SDA Y1A Y2A
These devices are designed for low cost mobile and consumer electronics applications.
QMatrixTM technology employs transverse charge-transfer sensing electrode designs which can be made very compact and are easily wired. Charge is forced from an emitting electrode into the overlying panel dielectric, and then collected on a receiver electrode which directs the charge into a sampling capacitor which is then converted directly to digital form without the use of amplifiers. Keys are configured in a matrix format that minimizes the number of required scan lines and device pins. The key electrodes can be designed into a conventional Printed Circuit Board (PCB) or Flexible Printed Circuit Board (FPCB) as a copper pattern, or as printed conductive ink on plastic film.
- Вид монтажа: SMD/SMT
- Рабочее напряжение питания: 1.8 В ... 5.5 В
- Тип корпуса: MLF-32
QT60240ATG, QT60240 ATG
