Datasheet QT60240-ISG - Atmel Даташит Микроконтроллеры (MCU) 1.8 - 5.5 В 24 Chan QMatrix — Даташит
Atmel QT60240-ISG
Наименование модели: QT60240-ISG
25 предложений от 17 поставщиков
Микросхема Интегрированный чип особого применения, Touch Sensor Capacitive 24 Key 1.8V to 5.5V Surface Mount 32Pin MLF EP
QT60240-ISG
Atmel
80 ₽
QT60240-ISG
197 ₽
МосЧип
QT60240-ISG QS130
Atmel
TradeElectronics
QT60240-ISG
Atmel
Производитель: Atmel
Описание: Микроконтроллеры (MCU) 1.8 - 5.5 В 24 Chan QMatrix
data sheetСкачать Data Sheet
lQ
QT60160, QT60240
16 AND 24 KEY QMATRIXTM TOUCH SENSOR ICs
SCL /RST Y0A Y2B SMP SDA Y1A Y2A
These devices are designed for low cost mobile and consumer electronics applications.
QMatrixTM technology employs transverse charge-transfer sensing electrode designs which can be made very compact and are easily wired. Charge is forced from an emitting electrode into the overlying panel dielectric, and then collected on a receiver electrode which directs the charge into a sampling capacitor which is then converted directly to digital form without the use of amplifiers. Keys are configured in a matrix format that minimizes the number of required scan lines and device pins. The key electrodes can be designed into a conventional Printed Circuit Board (PCB) or Flexible Printed Circuit Board (FPCB) as a copper pattern, or as printed conductive ink on plastic film.
  • Вид монтажа: SMD/SMT
  • Высота: 0.9 мм
  • Длина: 5 мм
  • Рабочее напряжение питания: 1.8 В ... 5.5 В
  • Тип корпуса: MLF-32
  • Ширина: 5 мм
QT60240ISG, QT60240 ISG
На английском языке: Datasheet QT60240-ISG - Atmel Microcontrollers (MCU) 1.8 - 5.5 V 24 Chan QMatrix
