Datasheet Texas Instruments TMS470R1A384PGEQ — Даташит
СерияTMS470R1A384
МодельTMS470R1A384PGEQ
16/32-битный RISC-флэш-микроконтроллер 144-LQFP
TMS470R1A384 16/32-Bit RISC Flash Microcontroller datasheet
PDF, 629 Кб, Версия: E, Файл опубликован: 21 май 2008
Pin144144
Package TypePGEPGE
Industry STD TermLQFPLQFP
JEDEC CodeS-PQFP-GS-PQFP-G
МаркировкаTMS470R1A384PGEQ
Width (мм)2020
Length (мм)2020
Thickness (мм)1.41.4
Pitch (мм).5.5
Max Height (мм)1.61.6
RoHSНе совместим
  • Important ARM Ltd Application Notes for TI Hercules ARM Safety MCUs
    PDF, 61 Кб, Файл опубликован: 17 ноя 2011
    The purpose of this application report is to offer a convenient collection of references to application notes posted by ARM Ltd that apply to TI’s Hercules ARM Safety Microcontrollers. The document contains links directly to the ARM documents in the ARM On-Line InfoCenter as well as re-prints the ARM introduction chapter to help you better determine if you want to investigate further.
  • 3.3 V I/O Considerations for Hercules Safety MCUs (Rev. A)
    PDF, 103 Кб, Версия: A, Файл опубликован: 6 сен 2011
    As new generations of microcontrollers lower their supply voltages from 5 V to 3.3 V and beyond, issues with interfacing and noise are increasing. This application report presents cost-effective interfacing techniques for inputs and outputs of 3.3 V microprocessors in an automotive environment. In addition, concerns about 3.3 V analog-to-digital converters (ADC) are discussed.
  • Semiconductors > Microcontrollers (MCU) > Other Microcontrollers > TMS470 ARM7TDMIВ®-Based Industrial MCUs
На английском языке: Datasheet Texas Instruments TMS470R1A384PGEQ
