Datasheet Texas Instruments TMS470R1A288PGETR — Даташит
СерияTMS470R1A288
МодельTMS470R1A288PGETR
16/32-битный RISC-флэш-микроконтроллер 144-LQFP
TMS470R1A288 datasheet
PDF, 572 Кб, Версия: B, Файл опубликован: 1 авг 2006
Pin144144
Package TypePGEPGE
Industry STD TermLQFPLQFP
JEDEC CodeS-PQFP-GS-PQFP-G
Package QTY500500
CarrierLARGE T&RLARGE T&R
Маркировка470R1A288PGETTMS
Width (мм)2020
Length (мм)2020
Thickness (мм)1.41.4
Pitch (мм).5.5
Max Height (мм)1.61.6
  • Important ARM Ltd Application Notes for TI Hercules ARM Safety MCUs
    PDF, 61 Кб, Файл опубликован: 17 ноя 2011
    The purpose of this application report is to offer a convenient collection of references to application notes posted by ARM Ltd that apply to TI’s Hercules ARM Safety Microcontrollers. The document contains links directly to the ARM documents in the ARM On-Line InfoCenter as well as re-prints the ARM introduction chapter to help you better determine if you want to investigate further.
  • 3.3 V I/O Considerations for Hercules Safety MCUs (Rev. A)
    PDF, 103 Кб, Версия: A, Файл опубликован: 6 сен 2011
    As new generations of microcontrollers lower their supply voltages from 5 V to 3.3 V and beyond, issues with interfacing and noise are increasing. This application report presents cost-effective interfacing techniques for inputs and outputs of 3.3 V microprocessors in an automotive environment. In addition, concerns about 3.3 V analog-to-digital converters (ADC) are discussed.
  • Semiconductors > Microcontrollers (MCU) > Other Microcontrollers > TMS470 ARM7TDMI®-Based Industrial MCUs
На английском языке: Datasheet Texas Instruments TMS470R1A288PGETR
