Datasheet Texas Instruments TMS470R1B1MPGEAR — Даташит
| Серия | TMS470R1B1M |
| Модель | TMS470R1B1MPGEAR |
16/32-битный RISC-флэш-микроконтроллер 144-LQFP
TMS470R1B1M datasheet
PDF, 542 Кб, Версия: A, Файл опубликован: 1 авг 2006
Купить TMS470R1B1MPGEAR на РадиоЛоцман.Цены — от 606 до 2 898 ₽13 предложений от 13 поставщиков IC MCU 32BIT 1MB FLASH 144LQFP. ARM7® TMS470 Microcontroller IC 16/32-Bit 60MHz 1MB (1M x 8) FLASH 144-LQFP (20x20). Embedded -... | |||
| TMS470R1B1MPGEAR Texas Instruments | 1 528 ₽ | ||
| TMS470R1B1MPGEAR Texas Instruments | 2 203 ₽ | ||
| TMS470R1B1MPGEAR Texas Instruments | 2 898 ₽ | ||
| TMS470R1B1MPGEAR Texas Instruments | по запросу | ||
| Статус продукта | NRND (Не рекомендуется для новых разработок) |
| Pin | 144 | 144 |
| Package Type | PGE | PGE |
| Industry STD Term | LQFP | LQFP |
| JEDEC Code | S-PQFP-G | S-PQFP-G |
| Package QTY | 500 | 500 |
| Carrier | LARGE T&R | LARGE T&R |
| Маркировка | R1B1MPGEA | TMS470 |
| Width (мм) | 20 | 20 |
| Length (мм) | 20 | 20 |
| Thickness (мм) | 1.4 | 1.4 |
| Pitch (мм) | .5 | .5 |
| Max Height (мм) | 1.6 | 1.6 |
- Vocoder Implementation Using TMS470 High-End TimerPDF, 326 Кб, Файл опубликован: 8 янв 2007
The TMS470 family of ARM7 microcontrollers contains a RISC coprocessor referred to as the High-End Timer (HET). The HET can implement complex I/O operations independent from the CPU, one of which is the capability to generate PWM signals. This application report describes using this PWM capability, along with an open source voice algorithm called Speex, to encode 8-bit voice messages without the n - UART Implementation Using the High-End TimerPDF, 120 Кб, Файл опубликован: 9 июн 2006
This application report describes how the TMS470 high-end timer (HET) peripheral can be used to implement multiple additional full-duplex high-speed universal asynchronous receiver transmitter (UART) interfaces with interrupt capability and zero ARM7 CPU overhead. The solution is provided for both TMS470R1A256 and TMS470R1B1M devices, but the information applies to other TMS470 family members as w - TMS470 Expansion Bus Module ExamplePDF, 126 Кб, Файл опубликован: 20 дек 2006
This document supplies information for using the Expansion Bus Module (EBM) on the TMS470R1B1M to interface to external memory and peripherals. The module supports the multiplexing of the input/output (I/O) functions and the expansion bus interface. When the I/O functions are not used, the EBM can be used to interface 8- or 16-bit memories. - Important ARM Ltd Application Notes for TI Hercules ARM Safety MCUsPDF, 61 Кб, Файл опубликован: 17 ноя 2011
The purpose of this application report is to offer a convenient collection of references to application notes posted by ARM Ltd that apply to TI’s Hercules ARM Safety Microcontrollers. The document contains links directly to the ARM documents in the ARM On-Line InfoCenter as well as re-prints the ARM introduction chapter to help you better determine if you want to investigate further. - 3.3 V I/O Considerations for Hercules Safety MCUs (Rev. A)PDF, 103 Кб, Версия: A, Файл опубликован: 6 сен 2011
As new generations of microcontrollers lower their supply voltages from 5 V to 3.3 V and beyond, issues with interfacing and noise are increasing. This application report presents cost-effective interfacing techniques for inputs and outputs of 3.3 V microprocessors in an automotive environment. In addition, concerns about 3.3 V analog-to-digital converters (ADC) are discussed.
Серия: TMS470R1B1M (2)
- TMS470R1B1MPGEA TMS470R1B1MPGEAR
- Semiconductors > Microcontrollers (MCU) > Other Microcontrollers > TMS470 ARM7TDMI®-Based Industrial MCUs
