Datasheet Microchip PIC16LF1508-E/SO — Даташит
| Производитель | Microchip |
| Серия | PIC16F1508 |
| Модель | PIC16LF1508-E/SO |
Debug Support • External debug header (AC244051/AC244052) is needed for debug support • Debug and Programming support is available via PICkit 3, and MPLAB ICD 3
PIC16(L)F1508/9 20-Pin Flash, 8-Bit MCU with XLP Technology
PDF, 4.0 Мб, Файл опубликован: 28 окт 2015
 Купить PIC16LF1508-E/SO на РадиоЛоцман.Цены — от 38 до 528 ₽18 предложений от 16 поставщиков IC MCU 8BIT 7KB FLASH 20SOIC. PIC PIC® XLPTM 16F Microcontroller IC 8-Bit 20MHz 7KB (4K x 14) FLASH 20-SOIC....  | |||
| PIC16LF1508-E/SO Microchip  | 38 ₽ | ||
| PIC16LF1508-E/SO Microchip  | 82 ₽ | ||
| PIC16LF1508-E/SO Microchip  | по запросу | ||
| Корпус | SOIC |
| Количество выводов | 20 |
| ADC Input | 12 |
| ADC with Computation | No |
| Angular Timer | No |
| Архитектура | 8 |
| CPU Type | 8-bit PIC MCU |
| CRC | No |
| Class B Hardware | No |
| Configurable Logic Cell | 4 CLC/CCL |
| Emulated EEPROM in Flash | 0 / HEF |
| High Voltage Capable | No |
| I2C | 1 |
| Internal Oscillator | 16 MHz, 32 kHz |
| Internal Voltage Reference | Yes Bandgap |
| Math Accelerator | No |
| Max 16-Bit Digital Timers | 1 |
| Max 8-Bit Digital Timers | 2 |
| Max ADC Resolution | 10 Bits |
| Max CPU Speed | 20 МГц |
| Max DAC Resolution | 5 Bits |
| Max PWM outputs | 5 including complementary |
| Количество компараторов | 2 |
| Number of DACs | 1 |
| Numerically Controlled Oscillator | 1 |
| Рабочий диапазон температур | от -40 до +125 °C |
| Operation Voltage Max | 5.5 В |
| Operation Voltage Min | 1.8 В |
| PWM Max Resolution | 10 Bits |
| Peripheral Pin Select / Pin Muxing | No |
| Pin count | 20 |
| Размер памяти программ | 7 KB |
| SPI | 1 |
| SRAM | 256 Bytes |
| Temp Range Max | 125 |
| Temp Range Min | -40 |
| UART | 1 |
| Zero Cross detect | No |
Серия: PIC16F1508 (44)
- PIC16F1508-E/GZ PIC16F1508-E/ML PIC16F1508-E/MLVAO PIC16F1508-E/P PIC16F1508-E/SO PIC16F1508-E/SS PIC16F1508-E/SSVAO PIC16F1508-H/MLVAO PIC16F1508-I/GZ PIC16F1508-I/ML PIC16F1508-I/MLVAO PIC16F1508-I/P PIC16F1508-I/SO PIC16F1508-I/SS PIC16F1508-I/SSVAO PIC16F1508T-E/GZ PIC16F1508T-E/ML PIC16F1508T-E/MLVAO PIC16F1508T-E/SO PIC16F1508T-E/SOV07 PIC16F1508T-E/SS PIC16F1508T-E/SSVAO PIC16F1508T-H/MLVAO PIC16F1508T-H/SSVAO PIC16F1508T-I/GZ PIC16F1508T-I/ML PIC16F1508T-I/MLVAO PIC16F1508T-I/SO PIC16F1508T-I/SS PIC16F1508T-I/SSVAO PIC16LF1508-E/GZ PIC16LF1508-E/ML PIC16LF1508-E/P PIC16LF1508-E/SO PIC16LF1508-E/SS PIC16LF1508-I/GZ PIC16LF1508-I/ML PIC16LF1508-I/P PIC16LF1508-I/SO PIC16LF1508-I/SS PIC16LF1508T-I/GZ PIC16LF1508T-I/ML PIC16LF1508T-I/SO PIC16LF1508T-I/SS
- Microcontrollers > 8-bit Microcontrollers
PIC16LF1508E/SO, PIC16LF1508 E/SO
