Datasheet AT89C5131A-TIRUL - Atmel Даташит Микроконтроллеры (MCU) 32K Flash 3 В USB — Даташит
Наименование модели: AT89C5131A-TIRUL
![]() 16 предложений от 12 поставщиков IC MCU 8BIT 32KB FLASH 28SOIC / C52X2 AT89C513x Microcontroller IC 8-Bit 48MHz 32KB (32K x 8) FLASH 28-SOIC | |||
AT89C5131A-TIRUL Microchip | от 344 ₽ | ||
AT89C5131A-TIRUL Atmel | 402 ₽ | ||
AT89C5131A-TIRUL Atmel | 458 ₽ | ||
AT89C5131A-TIRUL Microchip | 581 ₽ |
Производитель: Atmel
Описание: Микроконтроллеры (MCU) 32K Flash 3 В USB
Features
· 80C52X2 Core (6 Clocks per Instruction)
Maximum Core Frequency 48 MHz in X1 Mode, 24 MHz in X2 Mode Dual Data Pointer Full-duplex Enhanced UART (EUART) Three 16-bit Timer/Counters: T0, T1 and T2 256 Bytes of Scratchpad RAM 16/32-Kbyte On-chip Flash EEPROM In-System Programming through USB Byte and Page (128 bytes) Erase and Write 100k Write Cycles 3-KbyteFlash EEPROM for Bootloader Byte and Page (128 bytes) Erase and Write 100k Write Cycles 1-Kbyte EEPROM Data ( Byte and Page (128 bytes) Erase and Write 100k Write Cycles On-chip Expanded RAM (ERAM): 1024 Bytes Integrated Power Monitor (POR/PFD) to Supervise Internal Power Supply USB 1.1 and 2.0 Full Speed Compliant Module with Interrupt on Transfer Completion Endpoint 0 for Control Transfers: 32-byte FIFO 6 Programmable Endpoints with In or Out Directions and with Bulk, Interrupt or Isochronous Transfers · Endpoint 1, 2, 3: 32-byte FIFO · Endpoint 4, 5: 2 x 64-byte FIFO with Double Buffering (Ping-p
- Вид монтажа: SMD/SMT
- Серия процессора: AT89x
- Тип корпуса: SO-28
- Шина данных: 8 бит
- Ядро: 8051
AT89C5131ATIRUL, AT89C5131A TIRUL
