Datasheet AT89LP428-20JU - Atmel Даташит Микроконтроллеры (MCU) SingleCycle 8051 4K ISP Flash 2.4 В — Даташит
Наименование модели: AT89LP428-20JU
Купить AT89LP428-20JU на РадиоЛоцман.Цены — от 118 до 237 ₽ 11 предложений от 11 поставщиков 8051 89LP Microcontroller IC 8-Bit 20MHz 4KB (4K x 8) FLASH 32-PLCC (13.97x11.43) | |||
AT89LP428-20JU Microchip | 118 ₽ | ||
AT89LP428-20JU Microchip | 164 ₽ | ||
AT89LP428-20JU Atmel | 237 ₽ | ||
AT89LP428-20JU Atmel | по запросу |
Производитель: Atmel
Описание: Микроконтроллеры (MCU) SingleCycle 8051 4K ISP Flash 2.4 В
Features
· 8-bit Microcontroller Compatible with MCS®51 Products · Enhanced 8051 Architecture
Single-clock Cycle per Byte Fetch Up to 20 MIPS Throughput at 20 MHz Clock Frequency Fully Static Operation: 0 Hz to 20 MHz On-chip 2-cycle Hardware Multiplier 256 x 8 Internal RAM 512 x 8 Internal Extra RAM Dual Data Pointers 4-level Interrupt Priority Nonvolatile Program and Data Memory 4K/8K Bytes of In-System Programmable (ISP) Flash Program Memory 512/1024 Bytes of Flash Data Memory Endurance: Minimum 100,000 Write/Erase Cycles (for Both Program/Data Memories) Serial Interface for Program Downloading 64-byte Fast Page Programming Mode 128-byte User Signature Array 2-level Program Memory Lock for Software Security In-Application Programming of Program Memory Peripheral Features Three 16-bit Enhanced Timer/Counters Two 8-bit PWM Outputs 4-channel 16-bit Compare/Capture/PWM Array Enhanced UART with Automatic Address Recognition and Framing Error Detect
- Серия процессора: AT89x
- Ядро: 8051
- RoHS: да
AT89LP42820JU, AT89LP428 20JU
