Datasheet AT32UC3C2512C-A2ZR - Atmel Даташит Микроконтроллеры (MCU) 512 Кб FL, -40/125oC AUTO — Даташит
Наименование модели: AT32UC3C2512C-A2ZR
14 предложений от 11 поставщиков
Микросхема Микроконтроллер, MCU 32Bit AT32 AVR RISC 512KB Flash 3.3V/5V Automotive 64Pin TQFP T/R
AT32UC3C2512C-A2ZR
822 ₽
AT32UC3C2512C-A2ZR
Atmel
ЗУМ-СМД
AT32UC3C2512C-A2ZR
Atmel
AT32UC3C2512C-A2ZR
Производитель: Atmel
Описание: Микроконтроллеры (MCU) 512 Кб FL, -40/125oC AUTO
data sheetСкачать Data Sheet
Features
· High Performance, Low Power 32-bit AVR® Microcontroller
Compact Single-cycle RISC Instruction Set Including DSP Instruction Set Built-in Floating-Point Processing Unit (FPU) Read-Modify-Write Instructions and Atomic Bit Manipulation Performing 1.49 DMIPS / MHz · Up to 68 DMIPS Running at 50 MHz from Flash (1 Wait-State) · Up to 37 DMIPS Running at 25 MHz from Flash (0 Wait-State) ­ Memory Protection Unit Multi-hierarchy Bus System ­ High-Performance Data Transfers on Separate Buses for Increased Performance ­ 16 Peripheral DMA Channels Improves Speed for Peripheral Communication Internal High-Speed Flash ­ 512 Kbytes, 256 Kbytes, 128 Kbytes, 64 Kbytes Versions ­ Single Cycle Access up to 25 MHz ­ FlashVaultTM Technology Allows Pre-programmed Secure Library Support for End User Applications ­ Prefetch Buffer Optimizing Instruction Execution at Maximum Speed ­ 10,000 Write Cycles, 15-year Data Retention Capability ­ Flash Security Locks and User Defined Configuration Area Inte
  • Упаковка: Reel
  • RoHS: да
AT32UC3C2512CA2ZR, AT32UC3C2512C A2ZR
На английском языке: Datasheet AT32UC3C2512C-A2ZR - Atmel Microcontrollers (MCU) 512 Kb FL, -40/125oC AUTO
