Datasheet AT90USB647-AUR - Atmel Даташит Микроконтроллеры (MCU) 64K Flash; 2K EEPROM 4K SRAM; 48 IO Pins — Даташит
Наименование модели: AT90USB647-AUR
![]() 29 предложений от 16 поставщиков Микросхема Микроконтроллер, AVR USB 64K FLASH - 16MHz, TQFP, Ind Temp, Green | |||
AT90USB647-AUR Microchip | от 392 ₽ | ||
AT90USB647-AUR Microchip | 397 ₽ | ||
AT90USB647-AUR Microchip | от 1 484 ₽ | ||
AT90USB647-AUR Atmel | по запросу |
Производитель: Atmel
Описание: Микроконтроллеры (MCU) 64K Flash; 2K EEPROM 4K SRAM; 48 IO Pins
Features
· High Performance, Low Power AVR® 8-Bit Microcontroller · Advanced RISC Architecture
135 Powerful Instructions Most Single Clock Cycle Execution 32 x 8 General Purpose Working Registers Fully Static Operation Up to 16 MIPS Throughput at 16 MHz On-Chip 2-cycle Multiplier Non-volatile Program and Data Memories 64/128K Bytes of In-System Self-Programmable Flash · Endurance: 100,000 Write/Erase Cycles Optional Boot Code Section with Independent Lock Bits · USB Bootloader programmed by default in the Factory · In-System Programming by On-chip Boot Program hardware activated after reset · True Read-While-Write Operation · All supplied parts are preprogramed with a default USB bootloader 2K/4K (64K/128K Flash version) Bytes EEPROM · Endurance: 100,000 Write/Erase Cycles 4K/8K (64K/128K Flash version) Bytes Internal SRAM Up to 64K Bytes Optional External Memory Space Programming Lock for Software Security JTAG (IEEE std.
1149.1 compliant) Interface Boundary-
- RoHS: да
AT90USB647AUR, AT90USB647 AUR
