Datasheet AT90PWM2-16SQR - Atmel Даташит Микроконтроллеры (MCU) AVR 8K FLASH 3PSC, 16 МГц — Даташит
Наименование модели: AT90PWM2-16SQR
Микросхема Микроконтроллер, MCU 8Bit AT90 AVR RISC 8KB Flash 3.3V/5V 24Pin SOIC T/R
T-electron
AT90PWM2-16SQR
116 ₽
AT90PWM2-16SQR
Atmel
235 ₽
AT90PWM2-16SQR
442 ₽
ТаймЧипс
AT90PWM2-16SQR
Atmel
Производитель: Atmel
Описание: Микроконтроллеры (MCU) AVR 8K FLASH 3PSC, 16 МГц
data sheetСкачать Data Sheet
Features
· High Performance, Low Power Atmel® AVR® 8-bit Microcontroller · Advanced RISC Architecture
­ 129 Powerful Instructions - Most Single Clock Cycle Execution ­ 32 x 8 General Purpose Working Registers ­ Fully Static Operation ­ Up to 1 MIPS throughput per MHz ­ On-chip 2-cycle Multiplier Data and Non-Volatile Program Memory ­ 8K Bytes Flash of In-System Programmable Program Memory · Endurance: 10,000 Write/Erase Cycles ­ Optional Boot Code Section with Independent Lock Bits In-System Programming by On-chip Boot Program True Read-While-Write Operation ­ 512 Bytes of In-System Programmable EEPROM Endurance: 100,000 Write/Erase Cycles ­ 512 Bytes Internal SRAM ­ Programming Lock for Flash Program and EEPROM Data Security On Chip Debug Interface (debugWIRE) Peripheral Features ­ Two or three 12-bit High Speed PSC (Power Stage Controllers) with 4-bit Resolution Enhancement · Non Overlapping Inverted PWM Output Pins With Flexible Dead-Time · Variable PWM duty Cycle and Frequency · Sy
  • Вид монтажа: SMD/SMT
  • Тип корпуса: SOIC
  • Шина данных: 8 бит
  • RoHS: да
AT90PWM216SQR, AT90PWM2 16SQR
На английском языке: Datasheet AT90PWM2-16SQR - Atmel Microcontrollers (MCU) AVR 8K FLASH 3PSC, 16 MHz
