Datasheet ATUC64D3-Z2UR - Atmel Даташит Микроконтроллеры (MCU) UC3D3 64 Кб FL 85C — Даташит
Наименование модели: ATUC64D3-Z2UR
IC MCU 32BIT 64KB FLASH 64QFN. AVR AVR®32 UC3 D Microcontroller IC 32-Bit 48MHz 64KB (64K x 8) FLASH 64-QFN (9x9)....
ATUC64D3-Z2UR
246 ₽
ATUC64D3-Z2UR
369 ₽
ATUC64D3-Z2UR
ATUC64D3-Z2UR
Производитель: Atmel
Описание: Микроконтроллеры (MCU) UC3D3 64 Кб FL 85C
data sheetСкачать Data Sheet
Features
· High Performance, Low Power 32-bit AVR® Microcontroller
­ Compact Single-Cycle RISC Instruction Set Including DSP Instructions ­ Read-Modify-Write Instructions and Atomic Bit Manipulation ­ Performance · Up to 61 DMIPS Running at 48MHz from Flash (1 Flash Wait State) · Up to 34 DMIPS Running at 24MHz from Flash (0 Flash Wait State) Multi-Hierarchy Bus System ­ High-Performance Data Transfers on Separate Buses for Increased Performance ­ 7 Peripheral DMA Channels Improve Speed for Peripheral Communication Internal High-Speed Flash ­ 128Kbytes, and 64Kbytes Versions ­ Single-Cycle Access up to 24MHz ­ Prefetch Buffer Optimizing Instruction Execution at Maximum Speed ­ 4ms Page Programming Time and 8ms Full-Chip Erase Time ­ 100,000 Write Cycles, 15-year Data Retention Capability ­ Flash Security Locks and User Defined Configuration Area Internal High-Speed SRAM, Single-Cycle Access at Full Speed ­ 16Kbytes Interrupt Controller (INTC) ­ Autovectored Low Latency Interrupt Servic
  • Упаковка: Reel
  • RoHS: да
ATUC64D3Z2UR, ATUC64D3 Z2UR
На английском языке: Datasheet ATUC64D3-Z2UR - Atmel Microcontrollers (MCU) UC3D3 64 Kb FL 85C
