Datasheet Texas Instruments LM3S1R26-IQR80-C5 — Даташит
СерияLM3S1R26
МодельLM3S1R26-IQR80-C5
Микроконтроллер Stellaris LM3S 64-LQFP от -40 до 85
Stellaris LM3S1R26 Microcontroller Data Sheet datasheet
PDF, 4.6 Мб, Версия: I, Файл опубликован: 3 июл 2014
Pin6464
Package TypePMPM
Industry STD TermLQFPLQFP
JEDEC CodeS-PQFP-GS-PQFP-G
МаркировкаIQR80LM3S1R26
Width (мм)1010
Length (мм)1010
Thickness (мм)1.41.4
Pitch (мм).5.5
Max Height (мм)1.61.6
RoHSНе совместим
  • Using AES Encryption and Decryption with Stellaris Microcontrollers (AN01251) (Rev. B)
    PDF, 113 Кб, Версия: B, Файл опубликован: 8 янв 2010
    This application note describes the following four encryption methods used with AES: Electronic code book (ECB), cipher block chaining (CBC) or chained encryption, cipher feedback (CFB), and counter (CTR). These methods are described in more detail to help you select the appropriate method(s) for your application. The encryption package described in this application note is available with full sou
  • Configuring StellarisВ® Tempest- and Firestorm-Class and MCUs W/ Pin Multiplexing (Rev. C)
    PDF, 172 Кб, Версия: C, Файл опубликован: 6 ноя 2013
    Many members of the StellarisВ® family of microcontrollers provide system designers with a great deal of control over the placement and selection of peripheral module signals that are alternate functions for GPIO signals. This application note provides an overview of the pin muxing implementation, an explanation of how a system designer defines a pin configuration, and examples of the pin confi
Серия: LM3S1R26 (2)
LM3S1R26IQR80C5, LM3S1R26 IQR80 C5
На английском языке: Datasheet Texas Instruments LM3S1R26-IQR80-C5
