Datasheet Texas Instruments TMS320F28021PTT — Даташит
СерияTMS320F28021
МодельTMS320F28021PTT
Микроконтроллер Piccolo 48-LQFP от -40 до 105
TMS320F2802x Piccoloв„ў Microcontrollers datasheet
PDF, 1.5 Мб, Версия: K, Файл опубликован: 27 июн 2016
Pin4848
Package TypePTPT
Industry STD TermLQFPLQFP
JEDEC CodeS-PQFP-GS-PQFP-G
Package QTY250250
CarrierJEDEC TRAY (10+1)JEDEC TRAY (10+1)
МаркировкаS320 980F28021PTT
Width (мм)77
Length (мм)77
Thickness (мм)1.41.4
Pitch (мм).5.5
Max Height (мм)1.61.6
ADC7,13 Ch
ADC Resolution12-bit
CPUC28x
Comparators2
FPUNo
Flash64 KB
Тактовая частота40 МГц
I2C1
Рабочий диапазон температурот -40 до 105,-40 до 125 C
PWM8 Ch
Pin/Package38TSSOP, 48LQFP
RAM10 KB
SPI1
Total Processing40 MIPS
UART1 SCI
  • JTAG Emulators/ Analyzers: TMDSEMU100V2U-20T
    XDS100v2 JTAG Debug Probe (20-pin cTI version)
  • JTAG Emulators/ Analyzers: C2000-GANG
    C2000 Gang Programmer
  • Evaluation Modules & Boards: TMDSRSLVR
    C2000 Resolver to Digital Conversion Kit
  • Evaluation Modules & Boards: TMDSSOLARUINVKIT
    Solar Micro Inverter Development Kit
  • Evaluation Modules & Boards: TMDSILPFCKIT
    C2000 2 Phase Interleaved Power Factor Correction Kit with integrated power metering
  • Evaluation Modules & Boards: DRV8312-C2-KIT
    Three Phase BLDC Motor Kit with DRV8312 and Piccolo MCU
  • Development Kits: LAUNCHXL-F28027
    C2000 Piccolo MCU F28027 LaunchPad Development Kit
  • Evaluation Modules & Boards: TMDSCNCD28027F
    controlCARD with Piccolo TMS320F28027FPTT, InstaSPINВ™-FOC enabled
  • Evaluation Modules & Boards: TMDSIACLEDCOMKIT
    C2000 Piccolo MCU AC LED Lighting & Communications Kit
  • JTAG Emulators/ Analyzers: TMDSEMU100V2U-14T
    XDS100v2 JTAG Debug Probe (14-pin TI version)
    XDS200 USB Debug Probe
  • Fan Inverter by PMSM Sensorless FOC Algorithm Comply IEC60730 (UL1998) Base
    PDF, 438 Кб, Файл опубликован: 21 май 2017
    This application report presents a detailed solution to implement in fan motor applications based on TMS320F28021 microcontrollers. The solution uses the PMSM Sensorless FOC algorithm, and is also designed to comply with the IEC60730 (UL1998) standard.
  • Multi-DC/DC Conversion & Color LED Control Integrated on a C2000 Microcontroller
    PDF, 3.7 Мб, Файл опубликован: 1 фев 2012
    This application report presents a solution to control an LED lighting system using TMS320F2802x microcontrollers. The Piccoloв„ў TMS320F2802x series of devices are part of the family of C2000 microcontrollers, which enables cost-effective designs of LED lighting systems. With these devices, it is possible to control multiple strings of LEDs in an efficient and very accurate way. In addition t
  • High-Voltage Half-Bridge LLC Resonant DC/DC Conv SW w/ Synch Rectification Kit
    PDF, 825 Кб, Файл опубликован: 2 июл 2013
    This application report presents a solution to control a half-bridge LLC resonant DC/DC converter with synchronous rectification system using TMS320F2802x microcontrollers. The Piccolo;trade; TMS320F2802x series of devices are part of the family of C2000;trade; microcontrollers that enable cost-effective design of power supply systems. With these devices, it is possible to control power stages in
  • Digitally Controlled HV Solar MPPT DC-DC Converter Using C2000 Piccolo MCU
    PDF, 3.3 Мб, Файл опубликован: 29 май 2012
    This application report presents the implementation details of a digitally controlled DC-DC converter that is used as a front-end converter for solar inverter (DC-AC) application. It implements an isolated DC-DC stage with maximum power point tracking (MPPT) algorithm in order to utilize the full capacity of a 500W solar panel. It maintains its input voltage at the reference set point generated by
  • PSFB Control Using C2000 Microcontrollers
    PDF, 2.2 Мб, Файл опубликован: 22 май 2013
    The phase shifted full bridge (PSFB) converter is used for DC-DC conversion in various applications, forexample, in telecom systems to convert a high voltage bus to an intermediate distribution voltage, typicallycloser to 48 V. PSFB stage provides voltage translation as well as isolation from the line voltage, sincethis topology includes a transformer.This application report presents
  • TMS320F280x to TMS320F2802x/TMS320F2803x Migration (Rev. C)
    PDF, 119 Кб, Версия: C, Файл опубликован: 11 авг 2015
    This application report describes differences between the Texas Instruments TMS320x280x/2801x/2804x and TMS320F2802x/2803x microcontrollers to assist in application migration. While the main focus of this document is migration from 280x/2801x/2804x to 2802x/2803x, you will also find this document useful if you are considering migrating in the reverse direction. Functions that are identical in both
  • Piccolo TMS320F2802x/2803x Migration to TMS320F2806x
    PDF, 105 Кб, Файл опубликован: 1 мар 2011
    This application report describes differences between Texas Instruments' TMS320F2802x/2803x and TMS320F2806x microcontrollers to assist in application migration. While the main focus of this document is migration from 2802x/2803x to 2806x, this document is also useful if you are considering migrating in the reverse direction. Functions that are identical in both devices are not necessarily include
  • InstaSPIN(tm) BLDC Lab
    PDF, 1.4 Мб, Файл опубликован: 15 ноя 2011
    For this lab we are using the Three Phase BLDC Motor Kit with DRV8312 and Piccolo MCU (DRV8312-C2-KIT) (the DRV8302-HC-C2-KIT or DRV8301-HC-C2-KIT can also be used) with a Piccolo F28035 controlCARD subsystem to run the sensorless InstaSPIN BLDC technique.These are the tasks that must be done to spin motors:Make sure all physical connections and jumper settings on the kit
  • Accelerators: Enhancing the Capabilities of the C2000 MCU Family Technical Brief (Rev. A)
    PDF, 155 Кб, Версия: A, Файл опубликован: 8 ноя 2016
    Engineers designing real-time control systems are constantly faced with the challenge of optimizing performance. These systems require minimal processing latency in order to meet the control loop performance specifications. At the heart of the control systems are math intensive algorithms which are used to calculate the control signals. Utilizing a microcontroller (MCU) that can quickly and effici
  • Serial Flash Programming of C2000 Microcontrollers (Rev. B)
    PDF, 387 Кб, Версия: B, Файл опубликован: 8 фев 2017
    Often times, embedded processors must be programmed in situations where JTAG is not a viable optionfor programming the target device. When this is the case, the engineer must rely on some type of serial programming solution. C2000 devices aid in this endeavor through their inclusion of several program loading utilities included in ROM. These utilities are useful, but only solve half of the progr
  • EEPROM Emulation With the TMS320F28xxx DSCs
    PDF, 407 Кб, Файл опубликован: 21 сен 2009
    Many applications require storing small quantities of system related data (e.g., calibration values, device configuration) in a non-volatile memory, so that it can be used or modified and reused even after power cycling the system. EEPROMs are primarily used for this purpose. EEPROMs have the ability to erase and write individual bytes of memory many times over and the programmed locations retain
  • Programming External Nonvolatile Memory Using SDFlash for TMS320C28x Devices
    PDF, 2.0 Мб, Файл опубликован: 16 ноя 2009
    The C28xxx generation of microcontrollers can connect to external nonvolatile memory through a variety of interfaces including parallel, serial peripheral interface (SPI), and inter-integrated circuit (I2C). This application report discusses how to write drivers for your external nonvolatile memory to allow for in-place programming using SDFlash, an application provided by Spectrum Digital, Inc. A
  • Common Object File Format (COFF)
    PDF, 125 Кб, Файл опубликован: 15 апр 2009
  • TPS75005 Quick-Start Guide with C2000 Controllers
    PDF, 129 Кб, Файл опубликован: 17 янв 2012
    The TPS75005 is a complete power management solution for C2000 controllers from Texas Instruments. This document illustrates how to attach the TPS75005 to a C2000 controller.
  • Semiconductors > Microcontrollers (MCU) > Performance MCUs > Real-time Control > Piccolo F2802x/3x/5x/6x/7x
На английском языке: Datasheet Texas Instruments TMS320F28021PTT
