Datasheet AT32UC3A4128-C1UR - Atmel Даташит Микроконтроллеры (MCU) 128k flash Ind — Даташит
Наименование модели: AT32UC3A4128-C1UR
15 предложений от 15 поставщиков
IC MCU 32BIT 128KB FLSH 100VFBGA / AVR series Microcontroller IC 32-Bit Single-Core 66MHz 128KB (128K x 8) FLASH 100-VFBGA (7x7)...
AT32UC3A4128-C1UR
227 ₽
Рутоника
AT32UC3A4128-C1UR
543 ₽
AT32UC3A4128-C1UR
Atmel
821 ₽
AT32UC3A4128-C1UR
Atmel
1 692 ₽
Производитель: Atmel
Описание: Микроконтроллеры (MCU) 128k flash Ind
data sheetСкачать Data Sheet
Features
· High Performance, Low Power 32-bit AVR® Microcontroller
­ Compact Single-Cycle RISC Instruction Set Including DSP Instruction Set ­ Read-Modify-Write Instructions and Atomic Bit Manipulation ­ Performing up to 1.51DMIPS/MHz · Up to 92DMIPS Running at 66MHz from Flash (1 Wait-State) · Up to 54 DMIPS Running at 36MHz from Flash (0 Wait-State) ­ Memory Protection Unit Multi-Layer Bus System ­ High-Performance Data Transfers on Separate Buses for Increased Performance ­ 8 Peripheral DMA Channels (PDCA) Improves Speed for Peripheral Communication ­ 4 generic DMA Channels for High Bandwidth Data Paths Internal High-Speed Flash ­ 256KBytes, 128KBytes, 64KBytes versions ­ Single-Cycle Flash Access up to 36MHz ­ Prefetch Buffer Optimizing Instruction Execution at Maximum Speed ­ 4 ms Page Programming Time and 8ms Full-Chip Erase Time ­ 100,000 Write Cycles, 15-year Data Retention Capability ­ Flash Security Locks and User Defined Configuration Area Internal High-Speed SRAM ­ 64KBytes
  • Упаковка: Reel
  • Ядро: AVR32
  • RoHS: да
AT32UC3A4128C1UR, AT32UC3A4128 C1UR
На английском языке: Datasheet AT32UC3A4128-C1UR - Atmel Microcontrollers (MCU) 128k flash Ind
